Baltic Abrasives Technologies
Author Topic: What caused this in SYP log  (Read 814 times)
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« on: February 08, 2018, 07:57:37 PM »
what is this and/or what caused it?
Lightning?
2017 LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Offline Texas Ranger
  • Texan, by God and by choice.
Re: What caused this in SYP log
« Reply #1 on: February 08, 2018, 08:18:00 PM »
wind shake and a twig
Offline Ianab
« Reply #2 on: February 08, 2018, 09:45:06 PM »
I think both are branches. The top one you have just missed the knot, the lower one you have actually cut through the branch on an angle.
Eventually the branch has died and broken off, and healed over the stub, just before the tree was cut down.
Because the pattern in the growth rings goes all the way to the pith, that means that what ever created it has been there since the tree was a sapling, not some injury caused later, and I bet if you examine the bark of either that log, or the one it was cut from, you will see the signs in the bark of a healed over branch stub.
Lightning or a wind crack wont deform the growth rings in that way. They had to have grown like that, around a small branch.
Offline moodnacreek
  • Sawin by the notches
« Reply #3 on: February 08, 2018, 09:50:04 PM »
A wind crack; the problem with open grown trees.
Offline Southside logger
« Reply #4 on: February 08, 2018, 10:11:39 PM »
Around here that is known as a spike knot.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #5 on: February 09, 2018, 09:12:21 AM »
I guess there are exceptions, but most of the time a lightning strike will kill a pine.  Oaks not as bad to die.  Just what i have seen around this area.   Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
« Reply #6 on: February 09, 2018, 09:14:02 AM »
yup, on closer inspection what I thought was a crack, is a branch stub.  My bad.
question
What might have caused this staining on red oak?
Started by Delawhere Jack on Drying and Processing
Last post December 22, 2015, 05:39:51 PM
by GeneWengert-WoodDoc
this split bark was caused by...
Started by redpowerd on Tree, Plant and Wood I.D.
Last post March 24, 2005, 05:33:32 PM
by SwampDonkey
Lumber defects caused by foreign agents
Started by SwampDonkey on Drying and Processing
Last post June 19, 2004, 05:09:31 AM
by SwampDonkey
Has this forum caused you to spend more time in lumber stores
Started by brdmkr on General Board
Last post May 14, 2006, 12:23:47 AM
by beenthere
