TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Blade speed question  (Read 563 times)
Offline Kwill
  • Cedar cutter
« on: February 10, 2018, 12:57:49 PM »
In my sawmill plans it says this.
Any problems running between 3000-4000 like the plans say?
My pulley on my engine is 4 inch I was gonna go with a 10.25 pulley my tires are 21 inch. At 1800 rpm the blade speed calculator says around 3800. So I'm wondering if this will be fine?
Built my own log arch
In the process of building my sawmill
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Offline Kwill
  • Cedar cutter
Re: Blade speed question
« Reply #2 on: February 10, 2018, 02:20:04 PM »
OK according to that website my 13hp engine would be fine cutting at 4000 4200
Offline york
« Reply #3 on: February 10, 2018, 03:42:09 PM »
See if this helps you:
Albert
Offline starmac
« Reply #4 on: February 10, 2018, 05:14:37 PM »
WoW, I knew grits weren't fit to eat, but didn't know they were built on a sawmill down south. I am thinking our spruce grits would be even worse.
Offline CCCLLC
  • It's not to big, load it!
« Reply #5 on: February 11, 2018, 05:16:27 PM »
Lt40 with older Onan engine , blade speed at 4900 SFPM
New lt40 with deisel Yanmar, blade speed
at 5200 SFPM
Using a digital tach, didn't do the math.
Blade Speed
Started by EZ on Sawmills and Milling
Last post June 16, 2003, 06:32:20 PM
by EZ
Blade speed
Started by dra7 on Sawmills and Milling
Last post January 26, 2006, 08:07:47 PM
by Don P
question
WM Blade Speed
Started by Tobacco Plug on Sawmills and Milling
Last post July 23, 2003, 05:12:06 PM
by Bibbyman
Blade speed
Started by Kauff44 on Sawmills and Milling
Last post April 23, 2016, 09:46:17 AM
by Remle
