Arborwear
Author Topic: Correct Drivebelt Tension  (Read 583 times)
Offline Rougespear
  • Salmon Arm, British Columbia
« on: February 11, 2018, 01:14:53 PM »
Any thoughts on determining the correct drivebelt tension on the sawmill?  I'm wondering if my drivebelt is slipping some and causing the dipping and diving.  I do not have one of those "belt tension" gauges... Thanks!
Custom built Cook's-style hydraulic bandmill.
Offline slider
  • sawyer,trucker,tree service
Re: Correct Drivebelt Tension
« Reply #1 on: February 11, 2018, 01:24:35 PM »
I would get the gauge and find the specs for your engine . Crank shafts are not cheap.
al glenn
Offline Rougespear
« Reply #2 on: February 11, 2018, 01:30:50 PM »
Engine is a 1970s Wisconsin with an 1 7/16" shaft - I don't think max belt tension was every spec'd for this old engines.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: February 11, 2018, 03:31:48 PM »
Sorry... I forgot this was two parts. I made it all in to one picture.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline ladylake
« Reply #4 on: February 11, 2018, 04:06:30 PM »
 With how many # of pressure.  Steve
Offline Kbeitz
    • My Hobbies
« Reply #5 on: February 11, 2018, 04:36:26 PM »
I fixed it... Go back up and look again.
Online Southside logger
  • Sawing so I can afford to farm.
« Reply #6 on: February 11, 2018, 04:46:48 PM »
Would that same chart apply to belts with a tensioner pulley?  I ask as my book calls for 14lbs and 7/16" deflection
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline Kbeitz
    • My Hobbies
« Reply #7 on: February 11, 2018, 06:25:36 PM »
No idea... Sorry...
Offline squirrel dog
« Reply #8 on: February 11, 2018, 07:41:42 PM »
May be a little pricey but could you go to a cogged belt and pulleys.  like a timing belt.  i did that on my woodmizer years ago when mine was slipping in wide dense woods.  solved my problem.
Offline Ben Cut-wright
  • I'm new here! I'm old everywhere else
« Reply #9 on: February 11, 2018, 08:40:20 PM »
Can the deflection measurement be used with the chart you posted?  It appears the chart references much higher deflection pressures using a Burroughs tension gauge. This is a gauge I am familiar with as I own and use several models of that style.
Offline Randy88
« Reply #10 on: February 15, 2018, 08:27:29 PM »
You might want to consider into the equation belt stretch, as the belt runs and heats up, it stretches, at one time I knew what percent of stretch was allowable, I'm thinking maybe 3 percent or so.
There is also a difference in belts, I'd have to do some investigating again, but there are belts out there that have a very small percentage of stretch compared to average v belts, again not being able to remember exactly, but less than a half percent comes to mind on certain types of belts.    I went through this about a decade ago on a machine I built that is hydraulic motor belt driven.
Tom was Correct
Started by Bothy_Loon on General Board
Last post July 15, 2006, 12:57:16 PM
by Bothy_Loon
correct axe bevel?
Started by knowslittle on Timber Framing/Log construction
Last post February 28, 2010, 10:55:24 PM
by knowslittle
Correct Change
Started by Magicman on Sawmills and Milling
Last post December 27, 2012, 02:01:00 PM
by DR_Buck
What is the correct sparkplug for a Stihl...
Started by Red 93 L1 #3383 on Chainsaws
Last post June 30, 2009, 09:26:45 AM
by Stephen1
