Arborwear
Author Topic: Timber harvester hydraulic motor problem  (Read 517 times)
Offline climber2
  • We are nothing compared to trees...
« on: February 13, 2018, 04:39:49 PM »
Another day, another mill problem.
One of my hydraulic motors for my clamps developed a leak today. In figuring to replace it, I am at a loss for a part number or description. It is made by Eaton, that I know.
Any help is appreciated, thanks.
Timber Harvester 36htd25, 06 Ram 2500 5.9, 95 Chev 3500hd, 445ct Bobcat w/ Wallenstein winch, Bandit 200+, Morbark M12r, Countless chainsaws...
Offline 47sawdust
Re: Timber harvester hydraulic motor problem
« Reply #1 on: February 13, 2018, 04:47:51 PM »
If it can be rebuilt I have had good luck with Mid States Hydraulics in Alexandria,Minnesota.Very good people to deal with and not too far from you.
Good luck
Mick
Offline Josef
  • just horsin' around
« Reply #2 on: February 13, 2018, 08:19:23 PM »
Is it the motor that raises and lowers the clamp? if so be sure to get a good match as they're plumbed together and a motor of different specs may not stay timed with the other one, allowing the clamps to be at different heights, making it easier to saw into inadvertently.
Joe
In my house I'm the boss, I know this because my wife said so, I only hope she doesn't change her mind!
New to me Timber Harvester that I'm learning to operate, been building a home built mill for a while, should be ready to make sawdust with it someday if I ever quit "modifying" the design.
Offline tylerltr450
  • Trust me I run SAP and a sawmill
« Reply #3 on: February 14, 2018, 09:01:34 AM »
I just checked quick this morning and I was unable to see anything also. The tag is just blank.
Timber Harvester 36HTD25 fully loaded
Offline Josef
« Reply #4 on: February 14, 2018, 08:07:20 PM »
Checked mine for tags, the motor that raises and lowers the clamp is a Prince ADM75-4RP, Surplus center has one for $110. (but their inventory shows only one in stock)
Joe
Offline climber2
« Reply #5 on: February 18, 2018, 12:30:47 PM »
Joe
Thanks Joe, that points my in the right direction
Offline JB Griffin
« Reply #6 on: February 18, 2018, 10:26:14 PM »
Check with clouser farms. He used to work for timber harvester until they closed. He might could help.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
How fast does a harvester chain turn when powered by hydraulic motor?
Started by Wes Lyon on Sawmills and Milling
Last post August 15, 2015, 07:57:11 PM
by boscojmb
Hydraulic leak in timber harvester
Started by True North on Sawmills and Milling
Last post January 10, 2010, 07:36:22 AM
by bandmiller2
i have a problem with my timber harvester mill
Started by gary on Sawmills and Milling
Last post May 02, 2006, 04:33:17 AM
by gary
Hydraulic issue with 546 valmet harvester
Started by nath78 on Forestry and Logging
Last post November 02, 2013, 09:28:01 PM
by nath78
