Its been awhile
Started by Jeff, October 15, 2018, 07:49:23 PM
Darrel
 8)  Ifins they load that easy, you don't need no stinkin hydraulics.  8)
Of course, I say that while using hydraulics.
1992 LT40HD
The slab pile is way bigger than the lumber. Lots of dry rot.
Uploading logs two - YouTube
Stephen
Looks like a great day in the woods. I'm jealous, as I sit in the office wishing my life away, lol.
I also saw a lot of poor wood that I haul out. At 50+ yrs, I have realized that my good wood is declining and as it dies and falls, that is when I haul it out to saw. :-\
Thanks for sharing your time with us.
1994 WoodMizer LT40G18. 69 acres mixed wood. 1952 ford tractor, Norse 290 winch, studed Norse ice chains. 45-66DT Fiat.
This mornings work before getting rained out just now. Its settled in for the day so I guess I can go back to the cabin, take a ed solo cup shower, sit down and probably not be able to move the rest of the day. :D
DPatton
You got one of those critters hanging in the shed tonight Jeff?
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
POSTON WIDEHEAD
Of course I've herd of deer. Good pic Jeff. Looks like you were close.
Got the cedar all sawn. Happy happy.
No bucks spotted yet.
Dave Shepard
Looks like the mill is cutting well. Did you get any of that tamarack sawdust between your fingers?  :-\
I dont understand. Color me dense. ;)
I may try and get some more useable lumber out of the tamarack if tammy let's me stay a few more days.
Dave Shepard
Any time I've sawn tamarack I've gotten nasty fine sawdust splinters between my fingers.
I think I've avoided it because this is all a bit punky on the outside.
Did you have any fried fish?
I figured as much :).  I am jealous.
DPatton
How's that new power plant working on the Woodmizer Jeff?
Running good. Don't miss the onan even a little bit.
DPatton
Good for you. Glad you are able to get some good use outta that machine again. What kind of project you got in mind for those cedar cants your sawing?
PA_Walnut
Looks like lots of PEACE!! Good place to setup camp for a month!  8)
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Sawing and seeing deer. What a life!!
No real plans on the cedar. The logs just needed to be sawn and not spend another u.p. winter on the ground. I'll haul them home and find a use for them.
I'm glad I learned my lesson earlier this year and always disengage the saw now when crossing behind it, which is every cut up here this happened after reengaging and starting towards the cut, not even to it. I'm still using bands that came with the mill.
Darrel
I always tell people, customers or whoever else, to stay away from that side of the mill and I show them pictures like these so they understand why. Being in the blades way could ruin your day.
1992 LT40HD
Percy
Quote from: Jeff on October 23, 2018, 12:41:24 PM
I've experienced that too.Happens enough that its more than a coincidence....My Ukrainian engineering skills tells be the blade gets a workout when spooling up to speed.  ;D
Stephen1
My Mill which is a 93 has clearance issues with my larger alternator, I had to bend a little steel.
