Arborwear
Author Topic: And another sawmill build thread...  (Read 14058 times)
Offline ljohnsaw
Re: And another sawmill build thread...
« Reply #100 on: December 13, 2017, 06:49:50 PM »
Back on reply #90, there is a picture (from March 2016) of my mill.  Here it was in February of 2017:
And again the end of March 2017 after about 18" melted.  Notice the head angle...
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline ljohnsaw
« Reply #101 on: December 19, 2017, 11:43:12 PM »
Went up today to try and get some milling done before the snow dumps again tonight.  The last snow was from Thanksgiving weekend - just a couple inches.  The forecast was for rain.  Here is what was left today - ground pretty well frozen but was able to use the SkyTrak
I put this big guy on to test the log clamp
Plenty of travel (1") and tons of pressure!  The only issue I had is a 2x2 tube is not exactly 2x2.  My tubes are ever so slightly rectangular.  Of my 3 log bunks that will accept the clamps, only one would fit correctly.  The other two would only take the clamp 90 off to the side.  I have a little grinding to do on the posts.
John Sawicky
Offline ljohnsaw
« Reply #102 on: February 01, 2018, 05:18:40 PM »
I've been pondering what to use to jack up logs to center the pith.  I have a few scissor jacks that could fit but it might be difficult to crank them as the jack has to rise between the bars on my log bunks.  The crank mechanism would be blocked by the bunk end posts.  I was out today hitting thrift stores and such and found this at a ReStore (Habitat for Humanity).  Maybe Kbeitz knows what it from.  I'm thinking an early 1900's car or truck?
BTW, the posting by clicking to insert link is working again (for me)!  :)
The "lug wrench" has a screw driver like end on it (to pop a hub cap?) and a hex nut hole in the other end lug nuts/bolts.  It doesn't fit in the jack correctly so I'm assuming there was a different handle for it.  I had to give it a shot of Blue Creeper to get the ratchet pawl to work properly and lubed the threads as well.  I like the flip top extension - might come in handy when I try it out on my mill (whenever the snow melts...) :-\  I'll probably make a slight U shaped bracket to fit on top to cradle a log so it won't want to roll off.
Not bad for $5.00! 8)
John Sawicky
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #103 on: February 01, 2018, 05:31:20 PM »
I have a jack collection with a few like that but I have no idea
what car it came from. E-bay is saying Model A A2
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline waynorthmountie
  • FNG that likes to tinker.
« Reply #104 on: February 10, 2018, 03:23:29 AM »
Can you provide more info and photos of your lift system. Seems pretty unique, how has it been working and how fast can you lift the head up and down.
Offline ljohnsaw
« Reply #105 on: February 10, 2018, 11:18:50 AM »
Here is a couple pictures when I first made it.  Things are a bit rusty now!  It is made from those big rolling file cabinets.  I added more stages of gear reduction to make it really easy to lift.  About 10 turns to lift an inch.  The center shaft turns the two outside shafts which haul the head up on four chains.  It used to free fall so going down was easy.  Now I have to give the handle a big spin and it will go down a couple inches.
John Sawicky
bugpeople's Butt and pass build thread
Started by bugpeople on Timber Framing/Log construction
Last post Yesterday at 06:43:32 PM
by Jeff
(Another) Sawmill shed design thread, but I could use some help
Started by AnthonyW on Timber Framing/Log construction
Last post January 19, 2015, 08:39:42 AM
by AnthonyW
(2 questions in one thread) Blades & Deflection HF Sawmill
Started by Kingmt on Sawmills and Milling
Last post September 25, 2015, 08:47:59 PM
by Kingmt
New Guy with my Sawmill Build
Started by Jimmysmill13 on Sawmills and Milling
Last post April 12, 2016, 09:27:48 PM
by Ox
