Shank question.
Started by Kbeitz, August 23, 2017, 12:42:42 PM
Kbeitz
I got this box of shanks from the junkyard. Box is marked new but they are far from that.
It says F8 on the box. Does anyone know what they might fit ? Are they worth keeping ?
The box has a date of 1013 stamped on it. Some of the teeth look in good shape.
Simonds Saw shanks. F8
Love machine shop work
and Wood work shop work
And now a saw mill work
moodnacreek
Those appear to be worn out bits in shank boxes.
Kbeitz
I guess I could weld them to a circle and make a de-barker.
dustyhat
Kbeitz, i have welded them to the end of a small shaft and reground them for a boring bar for aluminium,worked out pretty good just keep it cool so the carbide dont come of.
Don P
No carbide there, looks like they do fit my saw, holler if you need more  :D
Kbeitz
These bits are carbide. Two chunks on each tooth. The carbide is soldered in a L shape.
Putting it under a magnifier you can see the carbide is in two pieces .
Ron Wenrich
I never used carbide, but those don't look like they've ever been sharpened.  Any life left in them?
Kbeitz
Quote from: Ron Wenrich on August 24, 2017, 06:07:13 AM
Some look great. Some are chipped. I think they would be great to use for
media in a deburring machine. To good in my eye to trash.
So an idea is born and the Kb Debarker begins.   ;D
Bert
Yep those are carbide and yes they are whooped as far as sawing is concerned. I use the same bit. I'll send some pics of new vs old as soon as I get a chance
Saw you tomorrow!
Kbeitz
Quote from: Bert on August 24, 2017, 02:41:59 PM
Thanks...
JB Griffin
Those bits are JUNK as far as sawing is concerned.  Absolutely wore down to nubs. If new they would have had almost 1/4 in. of carbide on um.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
JB Griffin
The carbide when new would have been simply a small rectangular block with an edge bevel not L shaped.
Kbeitz
Why then is the carbide made with two pieces ?
I will get a measurement tommorow but I'm sure the carbide
Is over 1/4" in size
JB Griffin
JB Griffin
Not sure why the two pieces maybe they cracked after being ground so thin?
longtime lurker
TCT is very hard but quite brittle: once they get too thin cracks appear and thats replacement time.
Kbeitz
This is not cracked. Every tooth has two chunks of carbide soldered to
the shank. The front carbide is 1/2" long.  I'm not saying they aren't junk
but I will find a use for them.
grouch
I think you mean brazed instead of soldered.
Could you make a flycutter out of one of those? Or some kind of tool for your lathe?
Find something to do that interests you.
You are using the term shank incorrectly. Shanks are the semi circular part that holds the bits in the saw. They also form the gullet. You have bits that were put in a shank box.
Kbeitz
Quote from: grouch on August 25, 2017, 06:35:59 AM
I thought they was silver soldered?
Kbeitz
Quote from: Jeff on August 25, 2017, 06:46:47 AM
Thank you ... I was going by what it said on the box.
Learning something new every day here on this forum.
grouch
Quote from: Kbeitz on August 25, 2017, 06:51:46 AM
I can't tell by the photos and the few that I've seen were all brazed.
Can you scratch it or wire brush it and see whether it's silvery or brassy looking?
Kbeitz
Looks silvery to me under a magnifier...
grouch
Well, silver soldering stands up to hydraulic fittings, why not saw teeth. Learn something new every day. :)
