Author Topic: Building a mill.. FIRST LOG WAS A SUCCESS!!  (Read 13568 times)
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: Building a mill.. The winch..
« Reply #20 on: January 15, 2018, 02:11:29 PM »
That shouldn't be an issue. Your only using 3 foot of cable to raise a mill full height
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #21 on: January 15, 2018, 02:12:26 PM »
I ended up with acme threaded rod for raise and lower. Some ways I wish I had gone simple with a winch but have to much invested not to change.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #22 on: January 15, 2018, 03:09:28 PM »
Just a thought... If you use a worm driven winch you wont have
to worry about the handle getting away from you.
Only around $40.00 on E-bay. When you let go of the handle
it stays where you left it.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Jeff
  • Fearless Leader
« Reply #23 on: January 15, 2018, 03:20:43 PM »
And you could make it powered by taking off the handle and using a cordless screw gun.
Offline jwh f-100
« Reply #24 on: January 15, 2018, 03:57:44 PM »
That's what I was thinking but wanted to send it out for others thoughts.. I think it will be very minimal change, which will be divided when the cable is attached in multiple spots..
Well good. Because that's what I just ordered from HF..   I liked the looks of the handle on the front.
Thanks all
Why buy it when you can build it.
Offline Hilltop366
« Reply #25 on: January 15, 2018, 04:00:03 PM »
I had a worm gear winch on my DIY mill, it works but slow, I also had a brake on the saw frame to make sure it did not creep while sawing.
I can't remember the pull rating on mine but the larger the capacity the slower it will go. I guess that is why you often see a lift assist on factory made manual mills, a lift gas shock or garage door spring sort of setup then you can have a high ratio lift mechanism that is fast and requires little effort to move and hold in place.
If I was making a stationary mill and weight did not matter I would be tempted to use a counter weight.
Offline jwh f-100
« Reply #26 on: January 15, 2018, 04:15:08 PM »
I like the idea of a clamp and a torsion rod. I have my feelers out for some garage door parts..
I'm also thinking about some type of secondary tensioner/handle on the cable. It will tighten the cable just enough for the blade to clear the log while backing up, but leaving the winch in its original location.
Offline Kwill
  • Cedar cutter
« Reply #27 on: January 15, 2018, 07:15:38 PM »
what kind of acme did you use? I see surplus center has what they are calling lead acme thread. I would think it would be soft and wear out quickly
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #28 on: January 15, 2018, 08:26:56 PM »
Whatever linn lumber sent me. The threaded block is brass so the rods should last just fine. its 1". 5 turns per inch of travel.
The blocks are just solid so I think I am going to drill and tap them for grease fittings.
Offline Jeff
  • Fearless Leader
« Reply #29 on: January 15, 2018, 08:46:17 PM »
I wouldn't. I'd lubricate with a fine lubricant.  Grease, fine sawdust, threads, BAD!
Offline ljohnsaw
« Reply #30 on: January 15, 2018, 09:52:09 PM »
It depends on how you pronounce it!  I think they meant leed as opposed to led.  i agree, lead (led) would be pretty soft! :D
John Sawicky
Offline ktm250rider
« Reply #31 on: January 16, 2018, 07:45:23 AM »
I just tacked up a HF worm gear winch to my mill in process.  Yes it is slow to go from the bottom to the top.  For making 1 inch adjustments it doesn't seem too bad.  Works great if you remove the handle and use a cordless drill.
Offline Kbeitz
    • My Hobbies
« Reply #32 on: January 16, 2018, 09:48:31 AM »
Better yet if you attach a wheelchair motor to it.
Offline ktm250rider
« Reply #33 on: January 16, 2018, 11:34:00 AM »
Ugh, yup thats the plan.  Wouldnt you know I get a townwide email that a local resident is giving away (AKA FREE) a powered wheel chair.  Naturally i was number 2 in line and number 1 took it!
Offline Kbeitz
    • My Hobbies
« Reply #34 on: January 16, 2018, 11:36:04 AM »
Check the junkyards.
Offline jwh f-100
« Reply #35 on: January 16, 2018, 12:25:36 PM »
Good idea with the drill. I plan to put a small steering wheel on mine..
Here is a basic drawing of my saw head..
Offline FloridaMike
« Reply #36 on: January 17, 2018, 09:21:41 AM »
Or use a 12 VDC tarp motor.  I'm using one of these: LINK
Hope it was ok to post a non-sponsor link!
Mike
Mike
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #37 on: January 17, 2018, 09:39:42 AM »
I would be real interested to know how that works I am using a wheelchair motor.
Offline jwh f-100
« Reply #38 on: January 18, 2018, 02:49:34 PM »
Have you guys considered a power window motor from a car?
Offline ljohnsaw
« Reply #39 on: January 18, 2018, 04:31:27 PM »
I wouldn't think it would hold up.  Don't think they are made for the duty cycle (unless you have a 5-year-old...) or the power that would be required.
John Sawicky
success with a chainsaw mill
Started by TessiersFarm on Sawmills and Milling
Last post July 06, 2009, 09:28:07 AM
by Meadows Miller
moved
MOVED: Success on TMT's Mill
Started by Jeff on Sawmills and Milling
Last post June 01, 2015, 04:12:44 PM
by Jeff
Building a Mill?
Started by hhsdrew123 on Sawmills and Milling
Last post June 19, 2017, 02:09:16 PM
by JRWoodchuck
Mill building
Started by Buddyw on Sawmills and Milling
Last post November 09, 2013, 07:31:42 AM
by bandmiller2
