TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: New to forum Timber Harvester user  (Read 2600 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: New to forum Timber Harvester user
« Reply #20 on: February 10, 2018, 09:18:08 AM »
[/quote]
Yeah Close enough a little more south but in the general area.
[/quote]
I get down to black diamond antiques and renninger's flea market every so often
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline tylerltr450
  • Trust me I run SAP and a sawmill
« Reply #21 on: February 10, 2018, 09:26:02 AM »
[/quote]
[/quote]
yikes even renningers that's dedication to come that far for that.
Timber Harvester 36HTD25 fully loaded
Offline Kbeitz
    • My Hobbies
« Reply #22 on: February 10, 2018, 09:30:24 AM »
[/quote]
[/quote]
I really like a good flea market. I went to leesport flea market once. What a drive.
Best flea market on Pa is in Jacktown Pa. at the engine show.
Offline tylerltr450
« Reply #23 on: February 10, 2018, 09:48:29 AM »
Yeah that is a good one I was there before, nothing like a good flea market
Offline tylerltr450
« Reply #24 on: February 10, 2018, 02:47:38 PM »
Well guys the computer works again like it should runs perfect!
Here are perfect 1x1s
Offline paul case
  • Original wearer of the PCM.
« Reply #25 on: February 10, 2018, 02:51:21 PM »
Glad you were able to figure it out.
IF at first you dont succeed keep on tryin and eventually you will suck seed.
PC
pc
Offline Dewey
« Reply #26 on: February 11, 2018, 11:07:16 AM »
Probably a real dumb question here, but in the pictures of your mill it looks like the log stops are on the same side as the loader arms and it looks like the blade is sawing "away" from the log stops? That is backwards from the way I would have pictured it.
Greg
One of the best features of a Timber Harvester.... you saw into fresh cut would instead of bark..
Offline tylerltr450
« Reply #27 on: February 11, 2018, 09:08:08 PM »
Greg
Dewey,
That is the best part about the Timber Harvester, always cutting into clean wood instead of having to run the mud saw/ debarker all the time.
Offline 47sawdust
« Reply #28 on: February 12, 2018, 09:01:00 AM »
My WM does not have a debarker.After my opening cut I most always turn the log into the back stops,270°,so I'm cutting in to clean wood.I feel it makes a big difference in blade life and reduces the time spent cleaning logs.I still pay attention to the exit side of the log for dirt and rocks.I don't like to see sparks when I'm sawing.
Mick
Offline tylerltr450
« Reply #29 on: February 12, 2018, 02:31:38 PM »
With TH you are able to turn it once and you able to get into a clean piece of wood, that saves me so much more time then having to do that a bunch of times.
Offline Brad_S.
« Reply #30 on: February 12, 2018, 06:25:03 PM »
Timber Harvesters demise certainly wasn’t due to an inferior machine.  I still maintain that it was perhaps the best out there. Internal problems are what sunk the company.
Offline 47sawdust
« Reply #31 on: February 12, 2018, 07:08:57 PM »
They went out of business the year I started looking for a mill.I was disappointed.The man behind the business had built a firewood processor that was as fully featured as the sawmills.I agree with Brad,the mills were top shelf.
Mick
Need MAC User Help Re: Resizing Photos For My Forestry Forum Album.
Started by Chris Burchfield on General Board
Last post October 24, 2010, 04:55:12 PM
by terrifictimbersllc
New forum user looking for info on small personal sawmills
Started by tomb on Sawmills and Milling
Last post August 10, 2008, 08:31:37 PM
by den
Used Timber Harvester ???
Started by sprucebunny on Sawmills and Milling
Last post May 20, 2005, 07:38:52 AM
by sprucebunny
Timber Harvester
Started by Bri on Sawmills and Milling
Last post January 23, 2016, 10:33:11 AM
by Rougespear
