Arborwear
Author Topic: What blades to run on a Norwood lm 29  (Read 588 times)
Offline Maplehillfarms
« on: February 05, 2018, 09:29:05 PM »
I have a lm 29 been using sabertooth blades with 3/4 tooth spacing, can I go to a 7/8 and what will the difference be ?
Offline ladylake
Re: What blades to run on a Norwood lm 29
« Reply #1 on: February 06, 2018, 04:55:48 AM »
 The 7/8 will use a bit less power, the 3/4 will saw straighter in tough wood.   I use 3/4 most of the time.   Steve
« Reply #2 on: February 06, 2018, 08:37:20 AM »
Do you sharpen your blades and how often do you reset them ?
Offline ladylake
« Reply #3 on: February 06, 2018, 09:07:52 AM »
I sharpen my blades to 4 and reset when needed, most times the 2nd sharpening.  If cutting spruce or dried out pine I set heavy . The only blade I've found that cuts spruce good is a 3/4 pitch  4 and heavy set.   Steve
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #4 on: February 06, 2018, 07:45:07 PM »
Welcome Maplehillfarms,
what are you sawing most of the time and how big?
D
« Reply #5 on: February 06, 2018, 09:55:21 PM »
Pine poplar mostly nothing real big 24 at stump
Offline JB Griffin
« Reply #6 on: February 10, 2018, 12:20:36 PM »
Sounds to me that you need some 7/8" pitch 4deg blades.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline dgdrls
« Reply #7 on: February 10, 2018, 07:31:56 PM »
I believe some 7/8 pitch   8 deg or 7 deg,  would do well,
here is some more on the subject
http://forestryforum.com/board/index.php?topic=63126.60
D
Norwood blades
Started by r44astro on Sawmills and Milling
Last post May 15, 2012, 06:23:07 PM
by r44astro
Buying blades for Norwood LM 26
Started by Lazyguy on Sawmills and Milling
Last post August 30, 2014, 02:24:29 PM
by Lazyguy
Norwood and WM blades Antique timbers
Started by MartyParsons on Sawmills and Milling
Last post April 15, 2005, 08:19:05 AM
by MartyParsons
Recommended Sharper/ Setter for Norwood 1 1/4 Blades
Started by H60 Hawk Pilot on Sawmills and Milling
Last post October 20, 2009, 03:01:53 AM
by fat olde elf
