sawmill advice what is the best sawmill
Started by KY colonel, February 18, 2017, 07:50:04 PM
KY colonel
What is the best sawmill that will do cross ties for the price? Or what do you need to look for in a mill for ties. Thanks
WH_Conley
What kind of production are you wanting to run? That could dictate anything from a band mill to a Scragg. What support equipment will you have, how many people? At this point in time, who are you going to sell ties and side lumber to?
By the way, Welcome to the forum and what part of the state are you in?
Bill
paul case
For me it is which ever one is running at the time.
PC
pc
WV Sawmiller
KY,
   BTW - is this going to be stationary or portable?
   Welcome to FF. I thought I read recently where some of the primary tie buyers were no longer buying. I suggest you be sure you have a good stable market before getting too deeply involved.
dgdrls
Welcome KY Colonel.
To your question, IMHO a circle mill.
What's your thoughts or direction on sawing Ties?
Best
D
LeeB
4x4American
Boy, back in my day..
woodweasel
Dave Shepard
Dave Shepard
Quote from: 4x4American on February 18, 2017, 11:01:20 PM
Hurdle
I've seen a few YouTubes of Hurdle mills making ties. You'd need a full time loader operator to keep the logs coming and taking ties away.
You might want to search the forum on the state of the tie market right now before investing in a mill for expressly that purpose;
Ohio_Bill
Quote from: Jeff on February 19, 2017, 10:51:40 AM
I was thinking the same thing .
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Bandmill Bandit
IT is a very real possibility that wood ties will be a thing of the past in the very near future.
There is a company that is working with ALL the rail road companies and government researching a rubber composite tie that is proving to be extremely effective. There is currently about 3000 mile of them under test here in NA and about 10,000Km in Europe. They range in age from about 3 year old to about 8 years old.
So far the results are pretty incredible.
Government and rail Company approval for general use is expected in the spring likley May.
once approved the change out will ramp up as production allows to change out all wood ties with in 10 years.
When a rubber tie is worn to where it needs replacing, It goes back the the plant and is recycled in to a new tie.
JB Griffin
Cleereman. But seriously I can't recommend buying a mill just for ties now.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
KY colonel
Good info guys . I would want one that could do ties but that I could use on our farm for other projects.
ozarkgem
Quote from: JB Griffin on February 19, 2017, 12:37:53 PM
Times  two. I think all the tie mills on here have been cut back. Better do lots of looking around and talk to the tie buyers before jumping in too deep for that market.  JMO  Waiting a few months will not change anything and might save you a truck load of money. One for the farm is a different story.
BigZ La
Quote from: Dave Shepard on February 19, 2017, 10:31:37 AM
Hurdle
Had to look https://www.youtube.com/watch?v=pBYPYUAOEkI
4x4American
With that sawyer, you would need prolly 3 tail men, a loader operator, and a full time guy banding packs of ties :D
And maybe a guy feed coffee and water to the sawyer lol
East ky logging
The tie market is about gone here in east Kentucky I haven't sold any since last summer. As far as a mill I have a woodmizer lt 15 that I have sawed a lot of ties on and a lot of lumber. It's all manual but I about always have at least one person helping usually two and you can saw quite a bit in a days time.
They who can give up essential liberty to obtain a little temporary safety deserve neither liberty or safety- Benjamin Franklin
KY colonel
i see the woodmizer 15 is under 8k that would be great. i looked at norwood and a turner mill and they both was in that price range on simular mills. that sucks about ties but do you have a hard time getting rid of your lumber in east ky?
East ky logging
It's mostly in spurts seems like but I just saw when someone wants something I don't keep much on hand because I could never have what they wanted. Logging is my main business but sawing usually keeps us busy when it's to wet to do that. I could probably advertise and pick up more work but I've got about all I can handle now.
KY colonel
how would i find buyers in ky. also is there a market for the wood chips if you had a chipper?
