Tensioning a bandsaw with a torque wrench?
Started by JRWoodchuck, April 26, 2016, 03:43:01 PM
JRWoodchuck
Anyone use a torque wrench to tension their bandsaw blades?
Home built bandsaw mill still trying find the owners manual!
Bruno of NH
Yup
That's how my mill is set up 28 ft pounds .
Thomas mill out of  Maine
btulloh
Woodland Mills tells to use a torque wrench.  35lbs for the HM126
HM126
21incher
My Hudson HFE-21 blade tension is set using a torque wrench also.
JRWoodchuck
That is great! How big are the bands you guys are running?
Bruno of NH
btulloh
Length - 144 inch, Width - 1 1/4, THick - 0.042
HM126
JustGreg
Yep. 35ft lbs. I use a HF (Pittsburg branded) 3/8" drive torque wrench. I figure its accurate enough for the mill.
Woodland Mills HM126
Bruno of NH
never finished
 Me too. Ever since I broke a shaft guessing at it with a big adjustable wrench.
Kbeitz
Dont forget that everything changes big time if you get oil or grease on you nut...
Love machine shop work
and Wood work shop work
And now a saw mill work
JRWoodchuck
Welded a 3/4" socket to the end and put a 1/2" drive torque wrench to it got another 1/2 turn out of it before it went click at 35ft/lbs! Works great thank you guys!
