edger alignment
Started by spencerhenry, September 20, 2006, 12:46:38 AM
spencerhenry
i just bought an edger, a woodmizer with a 25hp gas engine. used, but only 70hrs. i have one small problem. as the flitches feed through, the rear of the piece pulls to the side opposite the engine. i dont have a manual yet, but i am guessing that the feed rollers are not aligned properly. what it means is that i end up with a board with a crook in it, only about 5/16 in a 10 ft piece, but i need it to be right. can anyone tell me exactly what i need to do.
thanks
Cedarman
Don't know anything about a WM edger, but have used an S&W edger for 14 years.
It must be level.  Each blade must be of the same sharpness, same number of teeth and square to flitch travel.
Gustavo
you must see  too  the rollers tracks
it must be  in a conic from
it must be on level ..
gustavo from argentina
thanks to the forum for share very value informations.
here i have got good information  and  over all   good friends
Gustavo
the coments  about blades  are very good too
same diameter, same     teeths  ,  same sharp angle
isawlogs
   First thing I would do is get the blades sharpened . That in itself just might solve your issue .
   Marcel
Gustavo
we had buy a new one    edger  and now we are in the same problem
boards move in laterals directions
we are   putting on level the feeder (in feed roller)
spencerhenry
i havent spent alot of time on it, too busy so far. but i think the majority of my problem was feed rollers with sap and sawdust build up. have edged some more lumber, and dont notice the problem as much as before. the amount of lateral movement as the piece feeds, is now so small, that for the product i am producing, it is not a problem.
my edger still has the original blades on it, though not fresh, they are not dull.
