Husky 346XP v Jonsered ???
Started by JDeere, February 02, 2012, 09:42:35 PM
JDeere
Can anyone tell me the Jonsered equivalent to the Husky 346XP? Thanks!
2013 Western Star, 2012 Pelletier trailer, Serco 7500 crane, 2007 Volvo EC 140, 2009 John Deere 6115D, 2002 Cat 938G, 1997 John Deere 540G, 1996 Cat D-3C, 1995 Cat 416B, 2013 Cat 305.5E
Ohio_Bill
Sorry don't know. But I have a 346xp and it's my favorite saw.
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Ohio_Bill
I just looked on there website and I would think it would be the CS2153C
Bill
Spike60
2153 is correct.
And the 2152 corresponds to the 353.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
JDeere
Thanks, reason I ask is that I just bought a 2152C and the shop owner told me it was the sister to the 346XP and I questioned that.
JDeere
Ohio_Bill & Spike60, Thank you for the info. I just researched what you told me on the Husky & Jonsered websites and called the dealer back. I reminded him he represented it as the equivalent to the 346XP. He is going to take the 2152C back and get me the 2153C for a small price difference.
Quote from: JDeere on February 03, 2012, 08:17:15 AM
Sisters can be sisters and not be alike...big/small, fat/skinny, light skin/ dark skin, same father, different father............. ;D
He didn't say they were twins or from the same litter. ;)
weimedog
Its a red 353 and it has the metal cases vs. the 350 based 2150. But it has the 353 top end vs. the 346 top end. Similar, but not the same.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Ohio_Bill
I think you will really like that saw. For its weight the power is amazing. I find myself using it to fell trees that I should be using my 70 cc saw for.  I have a Stihl MS260 which is about the same size, but I much prefer the 346.
Bill
Cut4fun
Spike or others. OE 346xp 45ccc equivalent Jonsered was? I'm having a memory laps moment.
hamish
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
oldbones
Quote from: Ohio_Bill on February 02, 2012, 09:46:41 PM
Can you explain why?
I've got a 357 and a 372. The 57 is balky, and I'm temped to dump it. I was thinking about the new 562, but also am thinking of going smaller and using the new saw mostly for limbing and felling smaller stems. My kid tells me I'm nuts. "That's dinky," he says. But I like the idea of not having to lug quite as much saw around, as long as it will do the work.
JDeere
Old Bones, Go with the 562 XP. I have a 372, 346, 455, 240 and the new 562XP. I have only used it for a few days logging but I can already tell you it is my favorite saw. Last year I did most of the felling in the woods with the 372 and kept the 346 on the skidder for limbing and the smaller trees. Since I got the 562XP the only reason I carry another saw is in case I get one stuck or it breaks down. You can carry the 562 all day and not be as fatigued as you would be hauling a 372 around. There is not much difference in weight over the 346 but the cutting power, balance and overall feel is the best I have ever had. FYI, we are cutting mostly hardwoods in the 12"-24" size.
oldbones
thanks, JD. That's helpful.
What length bar do you have on it?
John Mc
The 346XP is one of the best saws in the 50cc range. Light weight, nice balance, nice power for it's size, pro construction. If you are in the market for a lighter saw, it's tough to beat
The 562 XP is also a very nice saw, from what I've heard. I would have to differ with Jdeere's statement that there is not much difference in weight for the 562 over the 346. The specs for weight: 562 = 12.57#, the 346 = 11.0#. I consider almost 1.6# to be a significant difference... almost double the difference between a 562 and a 372.
I'd guess the deciding factor is how much of a difference the lighter weight makes to you, and how much power are you willing to give up to get it? If you are cutting 12-24" hardwoods as Jdeere is, you're probably not going to be happy using the 346. If you're cutting smaller trees or limbing, and carrying extra weight around is starting to get to you, you really ought to take a good look at the 346.
JDeere
Oldbones, I have a 20" bar on it. John Mc is correct I am sure on the weight difference. What I meant to imply was that the saw does not feel like a heavy saw at all, whereas the 372 gets to be a bear when you carry it all day, especially in 2' of snow.
John Mc
From all accounts, both the 346XP and the 562XP are great saws, but they have very different capabilities. Which is best for you depends on what you want to do with them, and what you are cutting.
I have old neck and back injuries form college wrestling, so I tend towards the lightest saw that will do the job, even if it means I occasionally have to be a bit more patient than I would with a larger saw. (I'm also not making a living at this - firewood and small scale logging is part of my fitness, recreation, and social program.) The trade off for carrying around less weight is worth it for me.
BTW, Jdeere, I hope my comment did not come across as an attack on you or your opinions. I do understand what you are saying about the 372 vs 562 (that's part of why the 357XP is currently the largest saw I own... the other part is that there just aren't that many trees that I'm cutting that are a problem to handle with a 16" bar. I have a 20", but rarely take the trouble to swap it out with my 16"). The 372 is big for an all-day job, especially if you are not in shape for it (which I am certainly not - weekend warrior syndrome here).
John Mc
John Mc
Might also be worth a look at the Husky 555. A bit lighter than the 562, and lighter on the wallet as well -- to the tune of about $100, if I recall. Still pro-type construction.
oldbones
I'm also a part-timer, although at 65, a half day of cutting feels like full-time.
I've got a 372, which has been great for felling some big stuff we sent to the mill. My kid, lived in OR for a while, and he put a 24-inch bar on it. The set-up has made easy work of felling stems 18 inches and larger.
I'm thinking of a saw to go with the 372 both for felling smaller trees and limbing. The 357 does that work  well. The saw hasn't been running great, though. So I'm wondering what would make sense as a second saw. I figure anything from 346 to 562 would work fine. I'm just curious about the relative merits of different models.
thanx for al the thoughtful comments.
JDeere
Quote from: John Mc on February 08, 2012, 12:31:59 PM
BTW, Jdeere, I hope my comment did not come across as an attack on you or your opinions. I do understand what you are saying about the 372 vs 562 (that's part of why the 357XP is currently the largest saw I own... John Mc
John Mc, Not at all. You gave Oldbones the facts and my post was based more on my personal impression of the saw. Based on the above posts he should be able to make a better decision for his needs.
Ohio_Bill
J Deere , Did you get your 2153C  and how do you like it ?
Bill
JDeere
Ohio_Bill, I am embarrassed to say I have not even started it since I got it. I have been logging 5-6 days a week from dawn til dusk and have been doing all my cutting with the Husky 562XP. If it is similar to the 346XP then I am sure I will love it. I have to say that dollar for dollar the 562XP is the best saw I have ever used.
Ohio_Bill
That is good to here about the 562XP. One thing that really impressed me about the 346 was the power to weight ratio.  Sounds like the 562 has that also. The older I get the more I appreciate a lighter saw.
Bill
