Building a band sharpner
Started by Kbeitz, October 28, 2016, 08:32:04 PM
Kbeitz
I thinking that I would like to make a band sharpener machine.
Today I picked up a 10" compound miter saw from the junkyard.
I cant find anything wrong with it and I already have 3.
So being that it's a compound saw I thought I could mount a
10" grind stone on the arbor and sharpen blades with it.
I can make the vise and feed unit.
So what do you-all think ?
Love machine shop work
and Wood work shop work
And now a saw mill work
Larry
My first thought was 10" bench grinders run at 1,750 rpm while 8" and smaller run 3,600 rpm.  I would really make sure the rock is rated for the speed your saw runs at.
Other than the above caution I think it might work ok.
Kbeitz
Quote from: Larry on October 28, 2016, 10:39:37 PM
Yea... I found a lot of 8 and 10" stones on E-bay. None has the RPM listed.
I sent a message to each one asking what the RPM is listed on the Stone.
I will not buy one without the RPM marked on the blade.
years ago I had a grind stone blow up and destroy parts of my shop.
I was lucky and did not get hit.
E-bay has 10" diamond stones for sale. I think they are high RPM.
Bluejay27
The bms500 spins at 4280rpm, so an 8" wheel for it might work, although you'd need a shaft spacer. Just don't buy a diamond wheel for sharpening steel blades, carbon diffuses into steel at grinding temps.
'98 Wood-Mizer LT40HDD42 Super, '08 LT40HDG28, '15 LT70HDD55-RW, '93 Clark GPX25 Forklift, '99 Ford F550
LeeB
I've read of an RAS used for the same thing you want to do so I can't see why not. Like you said though, be aware of max RPM.
Kbeitz
I got this coming from E-bay. Max 3600 rpm.
Norton 8 X 3/8 X 1 19A80-KV grinding wheel
Ox
If I was doing it, I'd use a CBN wheel with a cooling rig set up and just pull the thing through the gullet.  No fancy cams needed.
