Prentice 410D Loader - Hydro Pump Pressures
Started by hdpirtle, September 18, 2014, 11:44:07 AM
hdpirtle
I have a Prentice 410D loader and it has become weak over the years doing pull through delimbing.  I want to do a hydro pressure test on each of the 3 pumps but not sure what the pressures should be.  Anyone have experience with this loader that can give me an idea of what a good reading should be?
thanks.
kiko
Boom and stick main 2750psi ports 3000psi.  Swing main 2800psi port 3100psi. Certain functions will not have ports and work off the main.
