Tealite stand
Started by jamesamd, April 03, 2016, 10:17:48 PM
jamesamd
The first batch of 7 were made as Christmas presents.At that time I had no idea how to control the coloring of the petals.
I then made 4 more as gifts for My loves friends,that I experimented with more in depth.I finished them in 3 days and never took a picture but I learned.
An open frame with a drop-in tier.
Some scrap 2 1/2" copper pipe I split and annealed to flatten,then plasma cut the shape.
After engraving,coloring and shaping.
The bases glued and finished with lacquer and felt bottoms applied.
Next day after epoxy had setup.Ibrought them out on the front steps in the sunlight for a quick pic.
Front lit
And then backlit.
My control of the coloring process greatly improved after I found  could stop the  process at will by cooling the copper with compressed air at any point in the reaction.And if I missed My mark a little more heat would erase the color left and I could make a new attempt in seconds.
I sold My first one last Monday for $100.
Jim
All that is gold does not glitter,not all those that wander are lost.....
Bark Beetle
You don't work wood, you work with wood.
pasbuild
Could you explain the coloring process please.
If it can't be nailed or glued then screw it
yukon cornelius
Very talented! Thee coloring adds an awesome touch!
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Bruno of NH
Those are grand looking!!!
jamesamd
Quote from: pasbuild on April 03, 2016, 10:59:20 PM
pasbuild  ;D I apply direct flame from a propane torch to the outer edges of the petals attempting to heat them evenly,removing the heat every 5 to 6 seconds,to see if the copper is reacting,when coloring begins to happen,I start fanning the entire petal a few seconds ,remove flame and watch the change.It happens very fast the hotter the copper is.Starts violet and if to hot ends brown.Trick is to cool it with compressed air at the color You want,If it ends up brown, reflame surface and cool again or let it cool a bit and do over An extremely fast reaction,be ready.  ;)
Jim
lowpolyjoe
WOW :o.    Very cool project.  Thanks for sharing your technique.
