Wright 37 Sharpener
Started by Foxtrapper, November 30, 2014, 09:24:26 AM
Foxtrapper
I found a used wright 37 band blade sharpener, but don't know enough about them to make an educated decision on buying it.  The guy wants 350 for it.  But it is missing some parts, such as the band blade support brackets.  It comes with one cam which is a c 18 cam.  I currently use wm 10 degree blades, and I also have some 4 degree blades.  Anyone have an info on this sharpener that would help me out?  Need to know if the c 18 cam would work on these blades, and if not, whether or not I can purchase new cams for this..thanks. 8)
2014 WoodMizer LT28
york
Albert
Foxtrapper
Yea, I looked at their website, doesn't tell me which cams are for which blade profiles.  And their manual pdf file needs a password to open..never run into that before.  I have emails out to the company, but they haven't replied yet..thanks for the info..
2014 WoodMizer LT28
york
Not sure now,but few years ago U-CUT sold that sharpener..
http://www.u-cut.com/index.cfm
Albert
bandmiller2
Foxy, that's not a bad price for a decent machine. I don't own a Wright, a Cooks cats claw is all I've used. All the band support brackets do is hold the band level so it can feed into the machine without rocking. Its something you could improvise very easily. Have you seen the machine.?? Plug it in and run it you and the owner could support the band on each side and give it a short test. Has the owner ever used it.?? Don't be overly worried about cams I basically use one cam to do all, their very close just minor changes to the gullet. Most machines have an adjustable head to match hook angles. Frank C.
ladylake
 I run that sharpener, the 7/8 pitch cam will sharpen almost any 7/8 pitch blade with some minor adjustments but the 3/4 pitch cam won't work on a 7/8 pitch blade.    Steve
Foxtrapper
Quote from: ladylake on December 01, 2014, 08:54:09 AM
Don't happen to know what your cam number is do you?  Thanks for all the replies, I think I will be getting this, as I don't have enough to pick up the cat claw yet.
2014 WoodMizer LT28
ladylake
 I'll get those numbers for the 7/8 and 3/4 tomorrow .   Steve
Foxtrapper
Went and picked it up today.  Bought it from an Amish fellow, so there wasn't anyway to test it before I bought it.  Got him down to 300 for it.  Brought it home and the cam motor wasn't working.  Dang, so I did some trouble shooting, and replaced the cord, works good now.  Going out to set it up this afternoon and then i'll know more...should be fun.. 8)
2014 WoodMizer LT28
ladylake
There are a couple different holes on the height adjustment rod that will make the gullet dept. change, you may have to move from one hole to the other to match the gullet on your blades.  I've also shimmed the mounting block out some to match the gullet better when I sharpen at 4°.  Steve
Foxtrapper
Does yours have the correct blade support brackets ladylake?  Could you measure the length of each side, and the height and width of them if you get a chance?  Going to try to make some as the blade needs to be level according to the manual.  Thanks for all the help..
2014 WoodMizer LT28
ladylake
The 7/8 cam  is  C 18  and the 3/4 cam is C 8
Yes I have the correct blade supports but they would be hard to copy, I'd just use a sheet of plywood with some guides to keep the blade in place.  The blade support should be a little lower than the bottom plate of the clamp as you want the blade to ride on the bottom support on the clamp which is adjustable up-down some.  Steve
Foxtrapper
I rigged up some blade supports today, kinda work ok, blade feeds ok.  Sharpened one blade, but the profile doesn't look quite right.  I figured i'd waste a blade getting this set up.  Won't know how well it worked til I try one I guess.  I have the c18 cam, using woodmizer blades, 10 degree 7/8.  It grinds the tooth face, and the tooth back ok, but doesn't quite catch all the gullet.  I think it will just take some more adjustments to make it work.  Thanks for all the help, stay tuned, I may have more questions.. 8)
2014 WoodMizer LT28
Chuck White
Quote from: Foxtrapper on December 02, 2014, 02:59:54 PM
That could be all in the profile of the grind rock!
ladylake
If you set the hook angle a little less that will cause the height adjustment rod to ride farther out on the lift arm and will make the gullet a bit deeper, less hook saws better.   Or you could move the height adjustment rod to the hole closer to the mounting bracket which will also make a deeper gullet, then you can fine tune it by adding shims between the bracket and machine.  I'd just try a bit less hook first.   Steve
Foxtrapper
Quote from: Chuck White on December 02, 2014, 05:01:23 PM
This is my very first try at profiling a grind rock, so you may be absoultly correct in that assement.  I sawed some today, but didn't use the blade I sharpened yet.
2014 WoodMizer LT28
bandmiller2
Foxy, don't be overly concerned if you don't clean the gullet on the first or second pass. One of the advantages of sharpening your own is you can take very light passes and greatly extend the life of your bands. If your hitting the face and the back of the tooth your close. I have found a diamond grit wheel dresser to be fast and easy to dress wheels, not that expensive ether. Frank C.
goose63
bandmiller2 where did you find the diamond grit wheel ?
goose
thank you to all the vets
bandmiller2
Goose, its not a diamond grit wheel just a diamond grit wheel dresser used to shape the grinding wheel. I bought it at one of those woodworker wharehouse places but any industrial supply house should have them. I paid around $10.00 but that was 10 yrs. ago. Frank C.
Foxtrapper
Quote from: ladylake on December 02, 2014, 05:48:26 PM
By hook angle you mean the degree I set the sharpener to?  I have it set at 10 degrees now.  Although it wasn't quite 10 when I sharpened the blade I did.  I put that one on today for the last two cuts on a 6x6 cant, and it cut quite well, I was surprised.  Will give it a better work out tomorrow on a few full sized logs..
2014 WoodMizer LT28
Foxtrapper
Quote from: bandmiller2 on December 04, 2014, 07:17:58 AM
Ok.  I didn't get the full profile sharpened, but it did ok on the mill today, so maybe that isn't a big deal.  At least it didn't dive, and the cut looked good too..
2014 WoodMizer LT28
Foxtrapper
Thanks for the link, I got to go dig up some parts that are missing.. :-\
2014 WoodMizer LT28
Foxtrapper
Ok, so the blade I sharpened didn't last 100 bf before it started to scallop bad.  I didn't set the teeth on that blade, but have heard tell that setting the teeth on the first resharp isn't usually an issue.
I started making some better blade supports yesterday, not pretty, but are fully adjustable for up and down.  Still have to make the posts that will hold the blade on the machine.  Getting there slowly.. :)
2014 WoodMizer LT28
ladylake
Keep in mind any blade can get dull fast if you hit some dirt or maybe a small rock, try a few more.  I never set on the first sharpening unless I hit something so that shouldn't be the problem if any.  Are you taking enough off the face of the tooth to get rid of the rounded edges of a dull blade.   Steve
Foxtrapper
I have heard that set on the first resharp shouldn't matter, and I haven't hit any metal so they should be ok.  I think it had more to do with not having the blade properly supported when I sharpened it, so I made some better blade support arms.  Still have some finishing up on them to do, then will give it another try.  It could also be the rock profile isn't correct, so i'll check that as well.  Ladylake, you don't happen to know what the arbor size is on this sharpener do you?  I haven't pulled my stone off yet to check.  I have some other stones i'd like to try on it.  Thanks.
2014 WoodMizer LT28
ladylake
A 5/8 arbor.   Make sure the bottom of the blade is riding on the bottom plate  in the clamp, you don't want the outside blade supports too high.  Steve
Chuck White
Quite a few members on here don't set their bands every time, and have good luck with that.
I set mine every time, then sharpen.
Foxtrapper
Got the blade support brackets built, ugly as sin, but better than nothing.  A welder I am not.  I resharpened the blade I sharpened with it the last time, it seems to be better, it fed around alright.  I only did a light grind on it, gonna see how long it will last now..
2014 WoodMizer LT28
