LT70 Super Sewing Mochine
Started by 4x4American, October 30, 2018, 10:42:16 PM
longtime lurker
I've seen tubevids of the hurdle in action: they're a producer if you got the right logs to feed it. Of course you'll end up right back where you were before in terms of needing a whole whack of expanded support gear to make it run at capacity but.... thats what we do right? Everything the hard way until we bed it down then off on the next expansion :D
I had a guy was a bit of a mentor to me in another industry years ago. His advice was "bite off more then you can chew then chew like hell before it chokes you". He never mentioned the indigestion that comes with it at times, but nothing ventured nothing gained and all that. I'm just about back on my feet after that hiding at the start of the year, and when any sane person would be consolidating just to take a breather I'm bidding blocks of timberland that I've got no idea how I'd process the volumes, but guaranteed supply is the best kind of problem IMHO.
I've said it before : this industry isn't a career or a job - its a disease!
Southside
4x4 Was that the mill you told me about?
moodnacreek
Quote from: 4x4American on November 01, 2018, 07:36:22 PM
lmao thanks LL!
Next is a Hurdle mill with 3 blade vertical edger.  Already put deposit down on one.  1995 mill.  Just waiting for the loan stuff to clear.
Wow, that's not a toy.
Percy
lmao thanks LL!
OH MY!!!! This is just the cheapo 2 blade version....
Hurdle Machine Works Vertical Edger - YouTube
YellowHammer
Now that will be a real sewing machine!
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
moodnacreek
Hope you can get it set up about 8' off the ground as this solves many problems.
Busysawyer
You gonna get a debarker and metal detector? What happens if you hit metal with one them blades?
longtime lurker
Quote from: moodnacreek on November 02, 2018, 12:16:01 PM
Elevated construction sure makes life easy but the setup $ hurts. Pays in the long term though.
I've been tossing my "one day" greenmill setup around in my head for years, which involves a series of benches cut into the side of a hill. Log yard at the top, head saw on the first bench, resaw on the next one down, then drop a level to docker or edger or whatever, final level being stacking area and an open yard behind it for storage. Gravity assisted chains going down the hill from station to station etc etc Bays probably 25' wide which makes for cheap shed construction, floor bench levels say 5' elevation difference... but you could recess back into the next bench up for sawdust extraction including walk beside access to the scraper chains or to get at the bottom wheel of a big vertical band etc.
I saw the original idea in a US Forest Service or similar article from the 50's or so about mill layouts and I never have been able to find that article again.... but I remembered thinking how sensible it was to make use of gravity to flow your material, and being able to get at the underside of gear without either a pit that wants to fill with water when it rains or the one time cost of elevated construction. The big problem with elevated construction aside from cost being of course that you kinda gotta start with a plan and its pretty hard to vary from it once you've installed the first piece of gear.
I think for all of us it'd be nice just once to be able to set up right at the start wouldnt it?  I can afford the dream, anyway.
4x4American
Quote from: Busysawyer on November 02, 2018, 09:40:55 PM
Gonna try to get my neighbors debarker..mainly for exporting logs though but will also use it for tie logs or really dirty logs.  If you hit metal you just change the couple bits that got nicked and keep going.  Can swadge them later on to reuse.
Boy, back in my day..
4x4American
Quote from: Southside logger on November 02, 2018, 07:25:40 AM
Most likely..I been thinking about getting one for a couple years.  I tried to convice the pallet guy to buy one a few years back and have me run it but he said he's in the biz of making pallets not sawing lumber.  He has a scragg mill though
4x4American
Quote from: moodnacreek on November 01, 2018, 07:44:58 AM
Is there room for a taper lock pulley?
Room for it where and for what?  There is an unused pulley on the arbor
moodnacreek
Quote from: 4x4American on November 03, 2018, 07:46:34 AM
Though you said a pulley was roll pinned on a shaft and failed.      Will this be the first hurdle in n.y.s.?
moodnacreek
 4x4, the last time I watched an automatic carriage/ vertical edger run they dropped everything on a belt that ended into the mouth of a chipper. Two men pulled the lumber off this belt and never touched the slabs or sticks. More than once I have passed up buying a v. edger because I often saw alone so I accumulate flitch boards and edge latter. Sawing with a v. edger slows the sawyer down some but is much more productive.
JB Griffin
Hurdle makes tie mills, they have one purpose rip a 7x9 out of the log as fast as possible,  and ties have a tolerance of +/- 1/4". Maybe a good reason you don't see any in the land of high dollar hardwood.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
4x4American
I would agree, JB, that a 40' 2HB Hurdle is mainly a tie mill, yes.  They also make 48' 3HB and 60' 4HB mills that are designed for more than just ties, like pallet cants, crane mats, grade, primary breakdown feeding a resaw/gang, dimension lumber, etc.  Having a 3
blade edger, I could pump out toober fours like a bat outta hell.  They even offer a top saw and lo-pro vertical edger from the factory.  Simple setup, simple transportation.  Best modular mill I've know of.  If you see one in person you'll see it's beefy, like that one in your neck of the woods I almost bought.
4x4American
moodna crick I like that idear..except for 2 things..if they miss a good piece, kiss it goodbye.  Maybe one of the pullers needs to take a leak and the sawyer don't notice.  It won't accumulate on a green chain, it'll just be chipper food.  I like the idea of having a slab dump at the end trimmer.  That way the end trimmings and the slabs find their way to the chipper in one spot, and the trimmer main gives you more bang for your buck, and gives sawyer one less thing to keep track of.  I know of multiple guys who saw solo with a vertical edger, and they love it.  It's two steps instead of three, saw cab, green chain, saw cab, green chain...cut lumber in one shot from the saw cab. niice
JB Griffin
4x4, none of the products you mentioned demand much in the of accuracy.  For example,  pallet cants down here +/- 1/4" unless they get picky on us, crane mat timbers +/- 1/2" and don't even have to be all that square, grade +/- 1/8" unless its a special order, primary breakdown just take the bark off and make it squareish, dimension lumber all gets run thru a 4 head moulder anyway.
As you can see WAY different specs in the south where those mills are made.
JB Griffin
When we get an order for bridge timbers we saw them on the the Dominator cause the meadows can't hold the +/-0 tolerance they want.
moodnacreek
4x4; the sawyer would have a push button or foot pedal to stop/start the belt. [I have a overhead lever] I could never figure out a way to handle v. edger output on my set up.    Am very interested in your project.                        P.S. The old timers always called it the 'crick'.
longtime lurker
Do they have a linebar? You can do a lot to improve dimensional tolerance if you have a linebar: SOP here with this springy eucalypt stuff is to vary the pressure on your carriage knees against the linebar to compensate for log spring, which gets rid of a lot of the thick and thin issues that cause dimensional variations.
https://www.fwpa.com.au/images/processing/PNB291-1112A_processing_methods_for_SW_products_euc_plantations.pdf
diagram on page 15.
4x4American
Yea I'm not really worried about it for what I'm doing..what I mainly cut is cants grade and ties.  None of which have to be perfect.  The pallet shop I sell to now sends the important size cants through a sizer first anyways.
