Space X
Started by Jeff, April 25, 2013, 06:12:56 AM
The research there is really getting exciting for a space fan.  Here is a link to the latest test flight where the grasshopper rocket goes up, hovers, and then lands.
http://www.spacex.com/press.php?page=20130310
OneWithWood
How do they keep that rocket stabilized without fins, thrusters, or both?
One With Wood
I dunno, but its pretty amazing. :)
Quote from: OneWithWood on April 25, 2013, 11:20:10 AM
Probably by gimbaling the main motor. It will be able to swivel a few degrees in any direction to adjust for any tilt in the rocket. It will be adjusting itself constantly by tiny amounts to keep it's balance, like a seal with a ball on it's nose. You don't see any movement from a distance, but the computer and hydraulics will be working overtime  :D
Fins only work if you are moving fast and add weight and drag. Thrusters add extra weight and need extra fuel. Both undesirable things when you are trying to get something into space.
I read this in the link
Quoteusing closed loop thrust vector and throttle control
Maybe the precision control like used on Mars landings
pineywoods
Yup, one or more engines are gimbal mounted, just a big ball joint. Hydraulic cylinders to position the  engine. Big time hydraulic pump, usually driven by a STEAM turbine. Yeah, STEAM. Don't know for sure about this one, but most large rockets pump hydrogen peroxide through a catalyst where it decomposes into steam. That powers a turbine which drives the hydraulic pump and some monster fuel pumps.
Sonofman
It is good to see someone using modern technology. NASA has done a lot of things, but they are not adapting new technology very fast into their designs. They tend to do it the same way cause they have always done it that way and to change requires to much red tape. Red tape is best handled by scissors.
Located due west of Due West.
Holmes
That is quite interesting.
Think like a farmer.
mesquite buckeye
