Walnut boards thickness
Started by WOOD100, June 09, 2016, 12:47:57 PM
WOOD100
I have a walnut log. What is the optimum walnut boards thickness? I was thinking about 1 inch. What do you think?
Depends upon what the lumber will be used for.  Is it for your personal use or are you planning to dry/sell it?
Kcwoodbutcher
If I'm planning on selling it I go 1 1/8". At 1" I may lose a board or two because of drying defects. That extra 1/8" makes a difference.
My job is to do everything nobody else felt like doing today
bags
I cut 5/4 for the furniture/ cabinet makers around here. Depending on how the board dries--- Theres more than enough material to plane out any cupping, and keep your clients "happy".
I would saw it 1 1/8" thick for 4/4, 1 5/8" thick for 6/4, and 2 1/8" thick for 8/4.  If you saw at 1 1/8", then after drying and planing, 90% of it will clean up to 15/16" thick.  That is what most woodworkers want.
OffGrid973
If you get a nice couple slabs to bookmatch into a table you may get a buyer to pay much more. Depends on your market but slabs on either side of the pith and some 8/4 for legs and rails when you cut on the sides of the pith work great for a table project.
I usually only flat saw here for making furniture and hope to one day learn the techniques to maximize quality wood without introducing to much waste.
Your Fellow Woodworker,
- Off Grid
Personally I always preferred to glue up 1" boards matching opposing grain patterns for legs etc.  My theory was/is that they would be much more stable.  Anyway, I never had any problems with the glued up legs.
YellowHammer
1 1/8" is what I saw to.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
WIwoodworker
The easiest to sell is 4/4 which I also cut at 1 1/8". That assumes a nice relatively straight log. Good luck with your log!
Peterson 9" WPF
Carson-saws
I feel it depends on the grade of the log, both before you open it  and after the face cut.
Let the Forest be salvation long before it needs to be
carykong
Walnut logs have a long self life. I support the previous posts that the actual user will determine how you actually mill the log.
