John Deere 653G
Started by logloper, July 05, 2015, 08:11:26 PM
logloper
It acts like the propel motor is not releasing the brake all the way on one track. If you push the propel pedal real easy it works fine. If you push harder(normal), the track moves around real jerky. Only on one side. Does it in high or low speed.  Any ideas?
Polish Hammer
My 903j had the same issue I found a cut wire under the pedal that was barly connected contact the one sde would act jumpy because of the poor contact of the cut wire.
Cat 322c fmhw with waratah 622, Komatsu PC200-7 FM with waratah 622b, Timberjack 450b grapple, timberjack 660c grapple, Tigercat 630c grapple, John Deere 853j Buncher, echo saws
logloper
I will check for cut wires, thanks.
