Is this a good used 12" Jointer?
Started by Brad_bb, March 16, 2018, 07:58:53 AM
Brad_bb
Came across this 12 jointer on Craigslist for $900.  I went and looked at it.  Is this a good machine? Seems to run alright.  He fed a small piece of stock across it.  It has the original motor that is 5hp 3phase 220V 15A.  I'm wondering how this will do jointing a 10" or 12" piece of stock.  Would it be better with a bigger motor?  I'm going to have to either get a phase converter or change out the motor to single phase and I could increase the HP?
Thanks, Brad
Don P
I'm running a power fed 15" planer with a 3 hp motor, I wouldn't be too worried about horsepower if you keep sharp knives in it. Larger than 5 hp in single phase starts to get pretty spendy. I'd get a phase converter, opens up more options as you acquire more toys. Check tables and fence for twist/plane. Does everything move up/down, in/out freely. Pulleys rotate square and true, bearings quiet.
Greyhound
That looks like a great machine.  Plenty of power - no worries there.  I wish I could find something like that near me.
Kbeitz
Might be hard to get parts for... Not a lot of info out there on it.
jointer Sk-12FPN SECO
Love machine shop work
and Wood work shop work
And now a saw mill work
TKehl
Would be worth looking into a VFD with single phase in and 3 phase out.
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
muggs
my 20 inch Oliver jointer has 5 hp. It does not lack for power, because you normally don't make deep cuts with a jointer, and that is with a power feed.   Muggs
scsmith42
Brad, I would not change out the motor, as 3 phase motors usually have more torque.  A VFD or rotary phase converter would be my first choice.  The nice thing about RPC's is that you can get a larger unit and feed a three phase load center with it.  Then you can hardwire your equipment to the load center and have circuit breaker protection.
My main concern with that jointer would be the flatness of the in and out feed tables (they look a little thin).
Definitely plan on adding a 1hp power feeder to it - will make life much more pleasant.
Tom's 3638D Baker band mill
Brad_bb
How would you recommend to check flatness/twist of the in and outfeed tables?
Southside
Like the others said - plenty of HP - my 20" planer with traditional knives runs a 5 hp single phase and will take off 3/16" with no problem in dry wood.
White Oak Meadows
Don P
Flatness is a straightedge on the tables, then diagonally across them each way. Then project from the rear table over the front and check for consistent gap under the straightedge on the front table. A good long level works for that. This checks that the tables are in the same flat plane in relation to one another, neither running over a hill or down into a valley.
For twist use winding sticks, 2 straightedges one at the rear of the table perpendicular to it, one at the front. While one person holds them go down and sight them, they should plane in. then do the same for the other table. Then one on the front table and one on the rear table. Then do the same checks for the fence.
winding sticks are a good way to check timbers for twist as well, one at each end. Basically it magnifies the twist by being a couple of feet long and gives your eye 2 lines to home in on instead of looking down the entire plane.
Brad_bb
My electrician finally got back to me.  Said that a VFD would cost too much.  He said by the time we got a phase converter, installed, and a starter for the motor, probably have $2500 in it.
So I'm apt to shop around and see if I can find a single phase unit and see how much it costs.
A new grizzly 12" 3hp single phase with spiral head is $3300. That is less than the money I'd have in that 3phase used one ($900+$2500). Any reason I shouldn't look at one like this?  Any feedback welcome.
A powermatic of same specs is $7000.  Hmmm......wonder why such a difference?
Laguna unit which is 5hp, not 3hp, is $5000.
They all seem to have spiral cutter heads, but are any of them Byrd Shelix?  I've heard that's what you want.  I converted a lunchbox planer to Byrd Shelix.  That would be nice if they all shared the same cutters.
Southside
What about swapping out the motor to a single phase? A quick search on Ebay shows 5 hp starting at $216 with free shipping.  I just bought a starter for a 3 hp, 3 phase motor, brand new, for $70 with free shipping, your electrician seems to be a tad high on his prices to me.
White Oak Meadows
Josef
When changing out a 5 hp 3ph for single ph motor make sure you don't install a "compressor duty" motor on a machine intended to run for extended times. They will probably over heat under constant rated load as their duty cycle is usually no more than 50%. A "farm" duty 5 hp single phase motor at Tractor supply is just under $500 and will run all day at rated load. I swapped out quite a few 3ph motors last time I moved a shop instead of installing a rotophase and the tractor supply farm duty motors were my go to unit when I had a sale coupon. :)
In my house I'm the boss, I know this because my wife said so, I only hope she doesn't change her mind!
New to me Timber Harvester that I'm learning to operate, been building a home built mill for a while, should be ready to make sawdust with it someday if I ever quit "modifying" the design.
Don P
Take a look at kbeitz's rotophase, there are old threads on building them as well, I have about 1/10th what the electrician is quoting in one from scrounging parts and DIYing it.
The spiral head with the carbide cutters is superior to knives.  More than superior.  I would not invest in a jointer with knives.
I suspect that you would not be able to discern much difference in the Grizzly spiral head and the Byrd.
YellowHammer
I had the 12" Grizz extreme duty jointer, it was a good machine.  I jointed more maybe a few miles of wood with it.  The cutters aren't Byrd, but are pretty good.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Kbeitz
I put a wiring diagram drawing in my post... It's easy to make one. The only difference between my drawing and what you need would be the size of the capacitors. That part is easy. starting capacitor is 70-100 mfd per Hp and the run capacitors is 12 - 28 mfd's / Hp. All the little parts can be got off E-bay.
3 Phase rotary converter in General Board
petefrom bearswamp
My understanding is that Byrd cutters are oriented at a true helical angle while the spiral are straight.
Am I correct in this assumption?
My straight spiral planer wont handle much of a cut, It is 10hp..
One fellow I talked to says that this is because the cutters are always in contact with the wood while a straight knife has a millisecond of "rest" between cuts
Is this true or bogus.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
I'd say it is bogus.  In my experience, the carbide cutters are superior to knives, and last many many times as long.
Don_Papenburg
I think that the straight spiral cutters do a better job on the finish of cut . The angled cutter is not arced and leaves micro lines on the board .  both will take less power and will be quieter than knives.
petefrom bearswamp
they do not take a deep cut I can attest to this,
this is with a freaking 10HP cutter head motor
My old Jet 15 inch straight knife would take this spiral head to the wood shed on the same width deeper cut. with a 3 hp motor.
My son and i planed Norway spruce 6" boards 2 aside at 3/32 inch cut at slow feed and if it went just a little over the cutter head stalled.
We were skip planing at 1" with rough sawing at 1- 3/32 which wielded 1-1/16 +/- and under on my WM.
I will agree that the spiral head makes a great cut but I have to put it thru too many times.
Sorry for the rant.
Wish I still had the Jet but want the extra width.
Kubota 900 RTV
PA_Walnut
Spiral cutter benefits:
  • Better cut
  • No tear-out with problem material like curly or figured (no comparison to knives)
  • Fast and easy replacement of a cutter or two if you hit metal
  • Rotate cutter 90° for a new cutting surface
  • Carbide
  • Quieter than straight knives
I've owned several versions of each and would not get a planer or jointer with anything other than a spiral, at this point. Dealing with curly maple a lot, makes it near essential.
Good luck.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
woodworker9
Brad
My offer still stands to teach you the ropes about 3 phase and running quality machinery in your shop if you're up to a ride to Crystal Lake.  $2500 is ridiculous.  I have machines running on VFD's, so I can show you that, and also 2 RPC's running different parts of the shop.  I can show you how to get set up for an entire shop for under $1K, and a lot less for just one machine.  It does pay benefits to be set up for potential future tasks, but that's up to you.
Let me know.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
petefrom bearswamp
Wow!!
Under 1K
I wish I had known of U when I set up my shop
Kubota 900 RTV
farmfromkansas
If you are considering a Grizzly, I have a G0609 with the Byrd cutterhead, and can flat joint nearly a 12" wide board with mine.  Lost about 1/4" when I put the Byrd on it.  The new ones have a cutter on the edge so you do not lose that 1/4".
