Book case shelf holes
Started by D._Frederick, January 10, 2012, 02:48:52 PM
D._Frederick
I want to build a book case that has moveable shelves with holes and pins to hold the shelves. The holes are 1 1/4 inches apart and I will drill them with my drill press, I don't want to spend $40 for a drill gauge.
Is there an easy way to get  the 1 1/4 inch hole spacing?
Radar67
Make your own gauge with some light weight metal or an extremely hard wood. I have seen metal rulers or yard sticks used with small bore holes, then a punch to mark locations of the holes to be drilled.
Raider Bill
I'm no carpenter or wood worker but I have used card board before. Set your spacing with a sharpie 10 or so rows/holes then just keep moving it up using the bottom 2-3 to line them up.
Texas Ranger
Or, make your own guide  out of scrap plywood.
sawwood
I have used a pice of pegboard, not sure what the spacing is but worth a
check out.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
CHARLIE
I do the same as Sawwood, I use a piece of pegboard that has 1/4 inch holes.  I've done it this way for years without any problems. Im guessing the spacing is 1 inch.  All that hole spacing isn't critical anyway and you can make 'em 2 inches if you want. Actually, I've found that once I've set the shelves in place, I've never moved them.  :)
Charlie
isawlogs
Is there a special reason to have them at 1¼" I have also used the peg board approche at spacing shelves, quick, easy and cheap... Cheao being key word  :D
   Marcel
T Welsh
Build a jig from scrap wood laying around the shop. the last time I had to use a spacing jig to drill holes I used my metal flat ruler and drilled holes in it ;D.It now has 3 sets of spacing holes drilled in it and works great. It also hang real well on the wall with all the holes in it 8). Tim
redbeard
If you have a drywall T square you could make it into  a shelf jig
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
D._Frederick
Years ago I made a router jig to cut dovetails using blocks cut to the spacing I needed moving the jig one block at a time then sawing a notch with a RAS. I thing this would work with my drill press with the right fixture. All I need is to come up with the fixture design.
You can plane the board used to make the blocks within a + or - .002 with know problem if you need that kind of accuracy.
terrifictimbersllc
