oleomac starting
Started by half, April 09, 2019, 07:59:07 PM
half
My 952 Oleomac has a start problem. If I push in the decompressor and give choke after a couple of pulls it fires.When cold easy. Then push the decompressor in again and it seem like there is no decompressor and it nearly breaks the cord
I have removed the decompressor and it is all ok the ports are clear and I can blow air through it easy But the problem returns when I replace it.
I am thinking it is preigniting for some reason
630red
did you check the decomp button clicks in and out,sometimes they go loose and compression on all the time
joe_indi
You should not be able to blow through it that easily. I have had this same issue on Husky 575. Simple fix was to replace decomp with a more restricted  Stihl decomp valve
