Timber Harvest Methods & Equipment
Started by Ron Scott, March 24, 2002, 02:14:52 PM
Quote from: 1270d on September 15, 2013, 08:12:34 AM
CTL is slower than a buncher job almost all of the time.  Some advantages of ctl are less ground disturbance and the ability to leave an better stand because of maneuverability.  For pure production though a hot saw, grapple combo take the prize
X2, another thing is that CTL equipment can often still work in conditions that shut conventional equipment down.
We have very few stands that wouldn't just be clear cut out right, so you have to be in nice stands to be able to justify it. And the wood has to be more valuable than pulp prices. They work here rain or shine. I've seen them aloud to destroy roads in wet conditions on public land to keep the wood flowing. We often get on a thinning block in the fall and some block is up for logging on the way in, so much for the road. Just think of the ruts on the land. We find them, when thinning, every one. ::)
semologger
1270d
That's unfortunate swamp donkey.  It doesn't do very well for our reputation.  The job I am currently cutting has a maximum rutting depth of eight inches, any more and we are shut down, or made to fix damage.  I try my best to lay good mat down in trails, but it is difficult when thinning to 80 ft2.
JLeBouton
Quote from: snowstorm on September 13, 2013, 08:17:22 PM
Quote from: CTL logger on September 13, 2013, 06:07:25 PM
I believe I saw that in escanaba last weekend isn't the barko equipment repainted Puma equipment?
it sure is
The two roller head on the machine is new. The machine itself has been tweaked.  The measuring system on the yellow four roller has been sorted out, and the first one is sold, and headed to Vermont.
snowstorm
Quote from: FABTEK on September 18, 2013, 08:11:35 AM
it sure is
now its getting interesting. lets hear more
JLeBouton
The pictured Barko harvester is a new design. It's essentially nothing like the Puma. Took some video of the machine running. I'll try to get it uploaded soon. My videos are never all that impressive, as they are usually taken during the first few hours of the machine's life.
...and more- here's the machine at the end of the woods road, the road was "slashed in" as it's called up here. I threw a bunch of tops, limbs, and a few whole trees across the trail to keep vehicles out, as per the forester's request.
snowstorm
Thank you- I can't spend too much time tidying my piles, I try to make them so they are easy for the trucks to load out of. I hauled out of enough scrappy piles when I drove truck ;) I make them as neat as I can, as fast as I can :)
Aspen and white spruce pulpwood-
Job finished, last look back 8) I've been driving almost 2 hours one way for this one.
I don't know what the problem is, I keep posting the same pictures ::)
Are these the ones,
Pulpwood picture
Last look
Ken
Several truckloads in them piles.  Nice big landings make life convenient.  I'm some glad our pulpwood does not all have to be 8' anymore.  Most of ours is cut 16'.  I too would be very happy to see a job done that requires a 2 hr one way drive.
Lots of toys for working in the bush
Yes, it's surprising how much wood is sitting in a pile. Even what looks like a small pile. ;D
keen
Nice pictures barbender, looks like a nice clean jobsite. If I could stack that good maybe my trucker would give me a better deal  :D
This was a job from this summer, our conventional crew cut this block (you can see the tree length piles in the background). They hand bucked the red pine logs and I forwarded them to the landing since I was on the same job. Pine markets are such in our area that logs don't pay as well as stud bolts, so if it is less than the 20" Max diameter that Potlatch accepts, it gets cut to 100" and sent to them. So all of these are over 20", 12-20' long. Poston, eat your heart out  ;D
A few more- conventional landing, JD limber, JD 748 skidder, and a Cat skidder, I don't remember the model.
The Cat grabbing a small bunch as I forward wood out behind him, it's fairly unusual for us to work next to each other like this.
Not all days are nice piles and big landings :(
It's not a big deal blowing a hydraulic line on the crane, but I sure dread the ones under the cab in the belly pan. It was about 95° that day, I know that won't get any sympathy from the southern members, but that's too hot for people that spend half the year below freezing ::)
OneWithWood
Too hot to be messing with hydraulics.  What a sweaty job...
One With Wood
pineywoods
At least you were smart enough to scrounge up a hunk of cardboard to lie on while crawling around underneath. Nothing like wallowing around in hot oil soaked sand.  ;D
Your right Piney, once my clothes get "hydraulic mud" on them they usually go in the garbage ::) So, it is nice to have something to lay on. That particular hose was the main supply line going to the valve block that feeds the crane functions, probably about 10 gallons sprayed out in the belly pan. I really hate losing toxic fluids on the ground like that, but there is really way to recover it when it happens that quickly :(
EricR
my JD 350b and international 504 with primero trailer
That looks like a nice set up, EricR. Do you cut for yourself, firewood or a sawmill?
