Check up
Started by Peter Drouin, April 16, 2015, 05:49:49 PM
Peter Drouin
I'm not using the Mill for the next 3 days, so I dropped it off at the Kennel with the rest of the cats.
;D
slider
What are we getting done ? I'm thinking,bigger turbo,larger nozzles,a little pump tweaking,advance the timing just a bit and BAM 20 more horse power.Off to the next shoot out.
al glenn
POSTON WIDEHEAD
Y'all got some nice CATS up there. ;D
Dave Shepard
Milton CAT in NY wouldn't warranty my Perkapiller. It was a battle, but I got it fixed under warranty. I'm told that had something to do with CAT getting replaced with Yanmar on WM mills. Doesn't bother me a bit. I'd rather have Kubota, but there's nothing at all wrong with a Yanmar.
Peter Drouin
When you get up to 1500 +/-- Hours you reset the valve slap says the Cat Book.
Well, I went past that a little  :D :D :o
The men will look at that , check the timing. And all the High and Low RPM setting.
Quote from: Dave Shepard on April 16, 2015, 08:14:00 PM
They did mine when I first got the supper, But nothing happen to the cat in that time. And it runs good now.
I don't have the tools or the know how to do all that.
I make 2x4s they make Cat's purrrrrrr  :D :D :D
4x4American
Petah I coulda set the valve lash when I was there!  Takes no time at all!
Boy, back in my day..
Don_Papenburg
Glad that you were not taking it in to get neutered ;)
Peter Drouin
Quote from: 4x4American on April 16, 2015, 10:30:06 PM
Well, what can I say. :D :D :D :D
4x4American
 :D   Them boys at Cat will be able to take good care of her.  If I were you I'd ask them to turn the pump up a bit get some more ponies outta her.  I know how you like to saw faster than Mario Andretti  :D
Delawhere Jack
Do I see a tandem seating arraignment on that mill? Which seat is for the pilot, and which one for the co-pilot?
Or maybe you just have REALLY LONG arms?  ;D
YellowHammer
Have them put one of those Dozer engines in your mill!  That would get the mill smoking.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Chuck White
Quote from: Delawhere Jack on April 17, 2015, 10:25:57 PM
There is a parking position at that location.
The seat is disconnected from the sawhead and it has a spring-loaded pin that snaps into a hole in the side of the main beam and the sawhead rests in the normal travel position.
4x4American
He runs the controls with his feet, it's a hoot to watch!
Peter Drouin
The cat is back in the barn and runs like a top, Guy said the valves needed just a little to be in spec.
The RPMs Idle at 1250 and high Idle of 3025
It was almost time to change the oil, so I had them do that and fuel filter too.
$400.00 Not bad.  8) 8)
Ga Mtn Man
Quote from: 4x4American on April 18, 2015, 08:40:45 PMHe runs the controls with his feet, it's a hoot to watch!
:D
