live edge slab display
Started by Joey Grimes, October 02, 2016, 05:35:16 PM
Joey Grimes
I'm trying to come up with a slab display and been thinking about a round vertical rack with the base mounted on a truck hub so it turns .The most difficult part about the slabs is displaying if you put them in a stack they don't sell well beacause no one can see them and stand them up vertical on wall they take up to much room. We're build a new lumber storage building so I'm brainstorming on how to maximize space .
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Okrafarmer
Yes, sir, good luck with that. I've had the same problem myself. Best thing I could do was lean them against a (strong) wall, biggest in back, smaller ones in front. I hope to have that problem again soon.  ;)
Now selling Logrite tools!
Den Socling
Are they dry and sterile? I hate some of the crap that is being sold as live edge slabs. But I have to hand it to you guys in the slab business. It's back breaking work.
longtime lurker
Give each slab a number, take pictures of each side, record dimensions... then stack them normally.
That way a potential buyer only has to look at pictures to come up with a shortlist of what's interesting to themselves. I tend to store "oddball inventory" pics to one drive, that way I can email a link and get the right slabs pulled for inspection before a buyer walks in the door.
(Link to off site photos removed by Admin)
(Couldn't get much uglier pictures of an ordinary log  to demonstrate with, but you get the method anyway!!)
YellowHammer
Quote from: Joey Grimes on October 02, 2016, 05:35:16 PM
I have the same problem...and also have to look at the potential danger to customers when they are sorting through the slabs.  I'm thinking of building a long vertical wall rack where the slabs are placed like books in a bookshelf, edge facing the customer, tilted back about 10 degrees, separated by wooden pegs spaced about 3 - 6 inches apart.  The customer can then see both sides of the slab, and pull the one they want.  I'm also thinking of looping a rope or light chain across the front of the display to keep any slabs from tilting out and falling on a customer, much the same way gas cylinders are held against the wall or in a welding cart with a safety chain.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Okrafarmer
Yellow Hammer, I believe you're onto something. Good idea. I always was worried about slabs or boards falling on people too. It never happened when I was set up that way, but your idea sounds real good.
red
Ever see a Canoe Trailer ?  I always thought it would be a good idea to have a rack or a trailer near the sawmill for sorting .
Joey Grimes
YellowHammer
Nice slabs, and that's how I've been selling them.  Customers dig through them, restack them, lean them against other stacks, mess them up, tilt them over,  and since some are 8 feet tall and very heavy, almost drop or tilt the them on themselves or other customers.  I haven't had any incidents yet, but I'm looking for a different, safer, way.  Got to remember, we may have 5 or 10 customers shopping and looking at the same time, so it's hard to keep my eye on everyone at the same time, and I shouldn't have to, if I had a safer, more convenient way to display and view the slabs.
YellowHammerisms:
Okrafarmer
Quote from: YellowHammer on October 04, 2016, 06:38:24 AM
:o
Wow, the most I ever had was about three different customers pawing through my wood at once! When do you find time to cut more slabs?  ???
YellowHammer
Quote from: Okrafarmer on October 04, 2016, 08:22:26 AM
:o
I don't sit down much  ;D.
Here's a picture I snapped a while ago of a typical Saturday with people buying wood and having a good time, at our place, at Hobby Hardwood Alabama.
YellowHammerisms:
Okrafarmer
I want to be like you when I grow up!
5quarter
YH...sure you don't have a Walmart there behind the barn?  ;) :D
Blue Harbor Refinishing
Joey Grimes
I need to work a lot on organization I have to do a lot of shuffling of stacks to find what customers are looking for  hopefully the new building will remedy that.
DR Buck
Here is a photo of what I made to use at shows.    It's a little hard to see the detail but it is two  8" x 8"  6 foot Poplar cants with holes drilled through them.    They are laid on the floor about 4 or 5 feet apart.   I cut and painted 3/4" rebar to go into the holes that are about 4 inches apart and I stand the slabs up in between the rebar.   The customer can see both sides of each slab.     I have longer rebar to use with the wider slabs.   If I remember correctly, the display holds 10 or 12 slabs at once.
FYI --  The display stands in front of the slabs are for the other "regular" boards and are made from plywood and Poplar.  They are made to come apart for transport and allow me to display boards safely for customers to look through without lifting them out until they are ready to buy.
xlogger
I recently clean out two 40 ft long metal building I have and put small rock on both floors. I filled all four walls with my slabs mostly cedar and maple. I then run my boards down the middle on pallets so you have room on both sides to walk and see the slabs and boards.
Cazzhrdwd
That is a nice set up Xlogger. I wonder though if a bit of saw dust covering the stone might look better? It would at least keep the ends clean. Might get a bit moldy if left for awhile though.
96 Woodmizer LT40Super  Woodmizer 5 head moulder
caveman
DanG Robert, you and Martha have folks coming out of the woodwork.
5quarter, those can't be Walmart shoppers frequenting Yellowhammer's establishment-none of them are wearing pajamas or sagging jeans.
Caveman
xlogger
Quote from: Cazzhrdwd on October 04, 2016, 09:45:17 PM
I keep them off gravel most of the time, this pic was taken right after I started filling up the area and had enough for one day. If you see the long boards on gravel, I built a long pallet type setup that runs the length of the wall that they rest on.
DR Buck
So my questions is are you guys selling green, air dried or, kiln dried slabs?    I would think stored over a gravel floor or in non-conditioned spaces at best they are air dried.     I have had no luck in selling much of anything not kiln dried except fence boards.   I have resorted to kiln drying almost everything now to get the best prices.
Den Socling
I've read an article or two about people selling air dried slabs that are spreading bugs and diseases like Thousand Cankers. Personally, I think it should be highly frowned upon if not down right illegal. Our forest have enough problems already.
YellowHammer
YellowHammerisms:
bkaimwood
Quote from: YellowHammer on October 05, 2016, 12:32:54 PM
Kiln dried and sterilized.
X2....the only way to fly!
Xlogger...great display! But the concern is selling slabs in a timely manner...if you don't, those KD slabs will take on moisture in a non controlled environment, and bow due to their own weight, especially with other slabs against them. They are encouraged to do so when MC changes. I have used a similar system, but in a somewhat controlled environment...and only one slab per space, to minimize these risks. Cuts down on space, bid time, but warped or twisted slabs speak for themselves. It's a real challenge, I'm fighting it with ya!!!
bk
Okrafarmer
Wow-- I sold a lot of green and air-dried lumber.
