I had an interesting job yesterday
Started by Tom, October 25, 2003, 06:26:17 PM
Florida Cypress Wood Products called and said that they had an order for a 22 foot long 12" x 12" that needed to be trimmed evenly from bottom to top such that the bottom was 12" x 12" and the top was 6" x 6".  Could I do it?
Sure, I said.
The brought it out to the house and we drew a centered 6" x 6" on the top of the timber.  I ran the mill head to the bottom of the mill and laid the blade against the timber.  It was 11 3/4 inches.   I then came back to the top of the mill and set the blade at 11 3/4".  Then I raised the timber with my hydraulic toe board until the top of the  drawing of the 6" x 6"  was even with my blade.  I raised an intermediate toe board to take the belly out of the timber and we sliced the top of the timber off.
Leaving the piece in place, I turned the timber 180 degrees and did the same thing again.  then we took those two "waste" pieces off and put them on their truck.
I turned the timber 90 degrees and went through the same procedure again.
Voilà!  a tapered timber as pretty as you please.
"What is this going to be" I asked.  I had been dying of curiosity and they wouldn't tell me.
"Is it going to be a flag pole?"   That's all I could think it would be used for.
"No, you're not going to believe this", said Bill Kavenough, the owner of Florida Cypress Wood Products.
"It's to have a pulley assembly affixed to the top 6" inch end and be shipped to New York, NY where they are doing a restoration.  It will be planted upright in the yard and a line will be run from the pole to a second story window.   :D It's a clothes line"  :D :D
"Well, I never........" I said, astounded, as he shoved money in  my pocket. :D ;D
What is really funny is that someone, later,  will ask him for a 3 x 12 x 22 or 3 x 6 x 22 tapered to nothing on one end and he'll sell more special cuts.  "Don't throw anything away!"
Bro. Noble
Tom,
I use that sawing procedure every once-in-a-while.
I use it to turn ties into pallet stuff when I forget to lower the tapers :-[
Looks like them tapered ties would be worth a premium for use on hillsides or banked curves,  but those buyers are pretty narrowminded ;)
Kevin
I wonder why they wouldn't just use a spar with a natural taper for a pole?
I think it all has to do with "Restoration", Kevin.  :D
Kevin
So they don't really need a clothes line then ?  :D
