Best welding rod for beginner
Started by chainsaw_louie, January 30, 2006, 10:46:17 PM
chainsaw_louie
Hi.
I just got the old Lincoln 225 AC welder hooked up and have been teaching myself to weld.  The welder was made in 1957 but it still works great! This is in preparation for building a sawmill.  Somebody gave me 20 or so electrodes and I have been burning them up, laying down practice beads on an old brake disk.  What do you guy suggest is the best rod for me to buy when I run out of what I have (not sure what it is either).   I guess that I will be welding mild steel about 1/4" thick.
And what sort of amperage do you generally burn these rods at on 1/4" steel?
Thanks.
Tim
scsmith42
6013 is commonly used by beginners.  More advanced welders will use a DC machine and use 6010 for deep penetration and 7018 for cap passes.
The amperage depends upon the metal thickness and rod diameter.  For an 1/8" rod on 1/4" plate, I'd try a range between 50 - 80 amps; probably starting around 70 amps.  You should have a smoother transition from the edge of your weld to the base metal.  If it looks "globbed" on top, you're probably need more amps.
Tom's 3638D Baker band mill
Coon
Tim  I think that this post would be better posted in the GENERAL BOARD.  It sounds like it would be more appropriate there.
Personally, I taught myself to weld and I generally use 6011's and 7014's for any welding that I have done but I am not positive if these would be right for the use that you intend.  I have not had very many welds break on me and I have burnt 100's of pounds of rods in my lifetime.  I have welded on farm equip, sawmill and logging equip, and numerous of projects that I have built over the years and will continue on hopefully for years to come.
Brad.
Norwood Lumbermate 2000 w/Kohler,
Husqvarna, Stihl and, Jonsereds Saws
getoverit
6013 and 6011 are good beginner's rods. The main thing with ANY rod is to make sure the rod is 100% dry when you weld. Welding rods have a tendency to absorb humidity from the air, and the wetter they are, the more they stick and splatter. A good dry rod will do some mighty pretty welds, even with ancient welders. Keep them in a "light box" (a metal box with a light bulb inside to provide heat) to keep the moisture out. The box should be fairly air tight. I have seen people use old refrigerators for welding rod boxes, but you would need to dry a BUNCH or rods to keep one this size running. you get the picture anyway...
I'm a lumberjack and I'm ok, I work all night and sleep all day
jrokusek
I think the 6013 rod is more of an advanced type of rod if I remember correctly.  6013 and 6011 (6010 too) are deep penetrating rods.  They work great but it is difficult to start a good arc.  Try the 7014 to get a good-looking weld.  It does a nice job, looks good, and holds well also.  Easy to start an arc too.  6013 works better for vertical surfaces, 7014 for horizontal surfaces.
Or....buy a mig welder and forget everything else I said!   :D
Jim
Dangerous_Dan
An easy rod to run and makes nice bead is 7018.
60XX series rod don't make pretty welds and are harded to keep an arc going.
7014 gives more "cut" than 7018 but has sloppier bead.
I use a mig for most of my welding these days but if I need to make a stick weld and I want it to look nice 7018 is the best standard rod.
If you want to spend some $$ and make some really nice welds check out Certanium (spelling??) rods.
I use these when it's gotta be perfect. ;)
First you make it work, then you trick it out!
toxedo_2000
Quote from: jrokusek on January 30, 2006, 11:14:43 PM
Jim
Yep, that is the thing to do. A Mig, will make a professional from your amateur skill.
Tox
Toxedo
Why walk when you can fly
Bob_T
Tim,
I've been a perpetual beginning welder for as long as I can remember.  I think most of the advice you got is good.  If you plan on buying 7014 or 7018 rod, read the box first to make sure it's suitable for an AC welder, as some of the various types are intended for DC only.  I think I've seen 7014 "AC" rod though.
Also, about MIG welders.  In the hands of a beginner they are notorious for making very nice looking welds that aren't very strong.  You can build just about anything you need with that old Lincoln AC machine.
There's more to a good weld than meets the eye and it's hard to teach yourself to be a good welder, even with the help of a book.  If you have a good community college system near where you live, they usually have night welding classes.   Some classes are geared towards training professional welders and are very good.
Bob
1959 FWD Model 286 Dump Truck
1955 Allis Chalmers HD-6G Crawler Loader
1941 GMC CCKW 6X6
Wood-Mizer LT30 G18
Jason_WI
7018 low hydrogen rod is a little difficult with an AC welder and overkill for most gen purpose welding. Works better on DC. 6011 will burn through the rust, paint and manure :-X to make a nice weld. We buy 50 lbs of 1/8 6011 at a time for the farm. Cant be beat for an all around gen prupose rod.
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
etat
Quote7018 low hydrogen rod is a little difficult with an AC welder and overkill for most gen purpose welding. Works better on DC. 6011 will burn through the rust, paint and manure  to make a nice weld. We buy 50 lbs of 1/8 6011 at a time for the farm. Cant be beat for an all around gen prupose rod.
Dang betcha!   :)
Start with 6011 for your  welder.  It will burn just a little bit hotter and pop just a little bit more than 6013, which burns just a little bit smoother but you will get better penetration and less slag in the weld.  Also it will make a stronger weld.  I always considered a 6013 just a bit weak for higher strength applications.
If you are welding anything structural stay away from 7018  until you learn to weld with the 6011.  While 7018 makes a nice bead it doesn't burn deep and doesn't make as strong a weld, especially if you start, stop while you are welding.  It works MUCh better as a DC rod.  Also it doesn't start penetrating as quickly, you can actually run a 1/4 inch or more without penetration if the welder isn't set hot enough.  If there's much of a crack in between the pieces they can fill the crack with slag and then weld on top making a weak joint.  That's why they burn smoother, because they have more slag to cool the puddle of hot metal,  however that more slag can get you in trouble if it mixes with the weld.
Your weld likely won't be quite as pretty as a 7018 but I'm absolutely guessing as a beginner it will be stronger.  When you stop for any reason be sure to chip the slag off before you stop back.  Slag is your friend for cooling the hot puddle of melted metal, but it is your enemy if it gets cooled underneath the weld.
For steel up to 1/4 inch I'd start with a 1/8 inch rod.  I welded with one of them little crackerbox lincoln welders for years.
Play with the amperage depending on the steel.  I'd start at around a 100 and work my way either up or down.  With the smaller rods you will be using, it is better to make multiple passes than to try to build it all up and one time.  There's LOTS to learn.
Years and years and years ago when I was working in a steel fabrication plant they actually gave me a whole BOX of 6011 rods, a pile of scrap steel, and turned me loose practicing.  They'd come by ocassionally and offer suggestions on making different type of welds.  When ALL of the rods were burned up they actually made me a fitters helper, tackwelding the steel as he fitted ti together and before it went to the welding shop.  That was my training grounds.
Old Age and Treachery will outperform Youth and Inexperence. The thing is, getting older is starting to be painful.
mike_van
The best rod I ever used was Cyrodyne 80 -  It was a little pricer than the 6013's etc. but ran nice beads up, down, & upsidedown too. The 7018 is terrible on an AC welder -
I was the smartest 16 year old I ever knew.
isassi
I have a different takeon this then the other guys, but here is my opinion: There is a 7018 rod available for a/c machines...i.e. 7018AC, not standard 7018LH. That said, if you want to develope the skill to strike an arc and control the arc and travel the weld puddle in different positions, try a pound of this rod. When you are learning, you are not trying to develope 70,000 psi weldments. From my teaching experience, starting and controlling an arc are the toughest things to learn for a beginner. Once the technique is down, then moving to working on weld passes for deep penetration or overlays. Once you start, you will find a balance between amperage and rod size (use 1/8 as your general purpose rod, it will do anything up to inches of metal in multiple pass use. smaller rod for thin, 11 gauge or less). After you can strike and work an arc, then refine what you are doing by varying arc length, i.e., running the rod close will "cool" the weld puddle slightly, longer arcs spread the temp outward, weaving the weld bead covers a wider area, varying the weave with a deeper center point tends to drive penetration...or, make it easy and get a mig machine. I learned on an a/c machine and then did tech training and later teaching fundamental welding and i still do not own a mig. I use a Miller Bobcat 225 and we hang a lot of steel in the air (metal building erection) and while I can't speak for others and welding rod preferences, we use only 7018LH in 1/8 inch to cover every welding application and every position.  ;)I just remebered something my uncle that taught me to weld when I was much younger advised: When you weld, it should sound just like bacon frying in a too hot skillet when running 6011. Good luck with the welding, you will have fun.
TexasTimbers
I'm self taught and learned on a 7018 AC like joasis referenced. I like using the 5P+ too. I noticed no one mentioned this rod.
The oil is all in Texas, but the dipsticks are in D.C.
Todd
If you want to make porcupines I can help.....none of the rods I've ever tried had any welds in them :D :D ;D
Making somthing idiot-proof only leads to the creation of bigger idiots!
I've seen guys around here put their rods on a wood stove before welding with them.Good-bad I don't know,I only have a small mig,but what they welded for me is still together.
Daren
Quote from: kevjay on January 31, 2006, 08:47:46 AM
Yep, it is good, the slag cleans off easy. I bet I have used 1000 lbs of it.
chainsaw_louie, 20 rods? I threw 200 as far as I could in anger learning, better get some more :D. It's like riding a bike though, once you learn you never forget. I had to go to trade school to learn how, I was a union pipe welder in a past life, MIG, TIG, stainless steel, aluminum, cast iron.... I had a good teacher, my Dad was an instructor at the school. I think that is why I got so frustrated, he was/is GOOD and made it look easy. I kept forgetting he had been doing it every day for 20 years.
Experience is something you don't get until just after you need it.
mike_van
How I learned to weld - Part 1 - I bought a 3 ph Montgomery Ward  rear blade - rated about 20 hp I think - Every time I used it, it broke -  I got lots of practice on that baby -  :D  Welding, like a lot of trades, needs some OJT - a few hours from a pro can save you weeks of disapointment -
Sprucegum
As far as rods and temperatures go you already got all the good "beginner advice" you need.
Just keep in mind what you really have there is a "hot glue gun".  ;)
If you want to do a good job of glueing something together you makes sure the joint is a good fit and clean of all dirt, etc.
A good grinder has saved many a dubious weld   ;D  ;D
rbarshaw
Yep, a 4 1/2" angle grinder ;D, must have one, not only to clean and prep the weld but also to make the  :o horrible  :o weld look like a professional did it. :D :D :D
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
chainsaw_louie
Hey fellas thanks for all the good advice.
I posted here because I am going to build a sawmill, so I figured its related.
The post about 6011 sounding like bacon frying in a pan is EXACTLY what it sounds like,  those are probably what I have.
The amperage may be too high cause my welds are kind of full of holes.  But when I lay one over top it looks much nicer.   Anyway its lots of fun.
Thanks.
Tim
simonmeridew
Tim:
Around here they call the 6011 the "farmer's rod" because it'll weld through paint, rust and manure, and penetrates deeply. A digger type rod. Welds are strong but don't look as nice, at least for the part time welder. The rod box tells you what amp to use, for quarter inch steel and eighth inch rod, start with 90 amps. Go up to 105 amps and get deeper penetration but watch for burn through and more spatter--round blobs of steel all over the face of the work. Lastly, the 6011 is a superior rod for cutting and piercing--turn the amps all the way up and blast a hole in the steel where you don't have a drill big enough. Or cut your way through thick steel or big rebar. Give your machine some cooling time when you have the amps way up.
The other rod mentioned a lot here is the 6013. If you run a 6011 at 90 amps or 105 for a particular weld, you'll want to run the 6013 at the next higher amp setting: probably 120 amps or even 135. I forget what I learned but I think the flux is "organic" rather than "inorganic", not that it matters to me.  This rod makes a VERY nice smooth looking weld, I think not as much  strength and definitely not as much penetretion; I like to start out with a pass with the 6011 rod, chip off what little slag there is with this one, then make the final pass with a 6013 at a higher amp setting. It doesn't pop or spatter as much as the 6011 but you'll definitely get a slag layer with 6013 you'll need to chip off. If I really need a weld to hold I like the 6011 and put the coal right to it, so to speak.
Kubota L4400, Farmi 351
Skip
7018 wont trap slag, no porosity great for beg.
jkj
I use a gas welder, wire welder, and an arc welder.  The best thing I did was buy a couple of books on welding.  Both Lowes and Home Depot have, or at least used to have, good books. (The next best thing I did was acquire 8000 lbs of steel stock at nearly giveaway prices, but that's another story!)
The books not only describe when to use the various types of rods, but give advice on preparing the metal for welding, recommended current, how to handle different weld types and orientation, ways to practice, and how to evaluate your welds.  Chapters on necessary and useful tools and accessories, cutting with a torch, and SAFETY are invaluable, as well as plans and instructions for a number of useful projects.
I can't imagine learning to weld on my own without these books.  It would be trial and error, hit and miss, and I'd probably have more errors and misses.  An instructor would be nice, but even then, I'd want the books.
JKJ
LT-15 for farm and fun
isassi
A great book to help with welding is the text book I taught from, Modern Welding, any edition, available I am sure used from Amazon or on E-bay. The pictures and diagrams are useful, and the explanations of the technical aspects are easy to follow. Lots of information will be at hand concerning low carbon steel, cast, stainless, ect. that you need to know to really get a feel of what welding is all about. Lots of difference between "dobbers" and welders.  ;)
toxedo_2000
After more than 30 years of welding by myself, without any lessons of somesort, I bought a book about welding, all kind of welding. God, what I did learn in this book !
Anyway, I understood I was not a good welder, but I had made over the years all the jobs I had to do. I sold my old Miller, 230 amps, last year. I was not using it anymore. But I do work with a plasma cutter, acethylen torches, and 2 migs. The mig is so easy compared to the rod thing. And, maybe the weld is not as good as it would be with the stick and a good welder, but in my hands I not sure :-\  But everything hold pretty well together untill now ;D. And my work is a lot better looking. And I dont need anymore the little grinder ;) , well... not so often... And the thing I love, I dont have to fight with the flux anymore. 8)8)8)
Plus, now I can weld aluminium ! smiley_thumbsup_grin
Tox
Toxedo
Daren
Quote from: joasis on January 31, 2006, 09:08:59 PM
Yep, making sparks isn't welding. But I ain't preaching, making sawdust ain't samilling either. It all just takes PRACTICE and good advice from those who know. That's why we are here  ;).
pigman
I have never been called a " dobber" , but some of my weld beads do look like pigeon poop. ;)  As I tell everyone, I can weld anything. The problem is most of it will not hold. :(   On rusty farm metal I use 6011 and on clean steel I use 6013.
isassi
The term "dobber" popped out due to the number of guys who think they are real welders....heck guys, I have experience with a sawmill, but it doesn't make me a sawyer...to even come close, I need lots more experience. There are truckers, and guys who drive trucks...ect, ect. Here in Oklahoma, the oilfield specifically, welding is a serious art form and practice. To weld on the pipeline, you get your weld sectioned to look at it. Same for drill pipe used in rigs...you should see a 7 inch diameter collar with a 2 inch bore 30 feet long get a weld splice. Takes an hour and 15 pounds of 7018 and 7024 to make the root and fill passes and there are not any pin holes or the weld won't pass x-ray.  Since I have been out of that trade, I think they do an innershield method with robotic turning since good welders are in very short supply. We take welding tests, which members of the FF are familiar with, and pay and employment depend on it. Many years ago I tested at the AWG 5 level. Most pipeline welders would do a 3 or 4. 5 and above at that time were pressure vessule and boiler ratings. I doubt the new welding processes will ever get rid of traditional stick welding, just like computers will never get rid of a journeyman machinist who can truly make a part, I think it is important to learn the basics, no matter where you go with it. When I taught powerplant, lots of people said the recip engines are dead, lets move to the jet age, stop teaching all that crap about magnetos and carburators. My position was and is, you don't build a house without a good foundation, and basic mechanic skills should be learned before getting to advanced technology and not understanding how to apply torque or even how basic fuel metering works. I know welders who can say "6011" or 7018, and have no clue what the numbers mean. When you buy mig wire, do you specify what grade you get? :P
Daren
I have had to take an x-ray test to even get on a job many times. They set you up with 2 pieces of pipe in an akward postion, "bell hole" or "Arkansas bell hole" so you have to weld 360 degrees around the pipe, top, bottom and sides without moving it. It better look as good on the bottom as it does the top 'cause if they aren't needing welders bad, they can be picky. The weld may pass the x-ray test, but they can send you down the road by "looking you out". Which means the inspector can say "I don't like the way it looks" (or in some cases doesn't like the way you look). I was lucky I worked for one contractor from the day I started till the day I quit. I just had to test for certain jobs they had at Nukes or pipelines for the engineers or regulatory reasons. But I remember other guys stories of driving 1000 miles hoping to get on a big overtime job and getting sent home by the inspector.
isassi
I bet Darin, we have had the same experience. Its true with most occupations. Good welders are not looking for jobs, good carpenters are not looking, niether are machinists or most skilled trades. Of course, there are exceptions, but truly skilled craft people always seem to have a good job. Around here, the line is if they can start tomorrow, you don't want them. Lots of employers trying to hire guys away from competition because they are making machinists anymore...ect... ;)
Daren
One of my favorite tricks is "mirror welding". When you have to make a weld in such a tight space, like up against a beam or wall, you can't get your head around the back side. You get a mirror and hold it in one hand and weld with the other watching in the mirror what you are doing, that will mess with your head. The only thing worse, and I have done it a bunch, is if you are out making a pipe repair and you don't have a mirror. You have to take the rear view out ot the company truck and use it (every truck I every drove the rear view had weld spatter all over it). What makes that so fun is a rear view has that day/night thing, if you look into it there are 2 images. That is a trip hanging upside down welding and trying to figure which arc to watch, good thing that part of the weld IS on the backside  ::), somethimes it wasn't as pretty.
Don't ask. :D
Welding experience is "senior dobber".  Got an AC buzz box along with acetylene torches.  Any suggestions on what rod to use?  Thinking about putting a sleeve over the repair...ya know how us dobbers are. :o
Sprucegum
If you want to revive a lost art  get some gas-welding filler rod (Hercules?) and use your oxy-acetalene to repair that break. It will be just as strong as 7018 if you do it right   8)  :P  ;D
jpgreen
oxy-acetalene-
That's what I've gotta learn.
My Father-in-law employs about 10 welders in his truck hoist fabrication company, in Sacarmento and cannot find decent welders anymore.  I said "Decent", not even skilled craftsman. His brother runs a hydraulic ram manufacturing business that was left to them both by their father, and it's full of lathe's and machines, and they can't find a decent machinist hardly anymore.
Where are the skilled high school shop teachers?...  Retired and few and far between. THis is today's America I guess.
Well- it's OK.  We always have Harbor Freight..  ::)
mike_van
JP, sadly, most of the machinests, tool & die makers etc. have been "outsourced" -  Across Connecticut are hundreds of machine shops now closed,  vacant - weeds in the parking lots -  The jobs gone overseas where labor is cheaper.
jpgreen
I don't get it Mike.  Where is all this going to shake out?  I'm a big Bush (W) supporter, but here he doesn't want us dependent on foriegn oil, but wants us totally dependent on foriegn labor and products (?)
Wants to support buiness with Mexico, China, etc., etc., but tell's GM "Oh well", you have to just take your lumps?  ::)
I miss Ronnie.  Sorry to highjack this thread.
isassi
Ok, so where did the skilled trades go???? Well, in Oklahoma, we had the finest technical training anywhere, and other states modeled their voactional training on our system for awhile...then the egg heads decided  we were teaching "lost" skills...totally un-needed in our new world of computers. Lets get with the jet age and leave behind the "old technology, embrace the new". When I was in highschool, I signed up for vo-tech machine shop. I graduated, just as the NC and CNC were coming on strong, as a journeyman manual machinist. With a few years experience, i was competant, and this was on that "old technology". The egg heads fired my traditional instructor, and taught computer programming for the machinists of the future, and look what we have now? Guys who can't chase a thread, sharpen a drill bit, or make a new part by measuring the old one. And God forbid, if the machinery breaks, they lack the basic mechanic skills to repair it or troubleshoot a problem if it doesn't come from a keyboard and monitor. Later in life, I was teaching Aviation Maintenance Technology, and the egg heads said "we don't need guys who can understand what makes it work, we need highly trained technicians who can work on space age vehicles". Now we have A&P's who can't time a magneto, rig flight controls, or have any troubleshooting skills on aircraft, but they know all about composite layups and the latest laptops that have replaced the service manuals of the past. As Darin pointed out with his welding background, and mine own experience, guys who can lay in the mud under a drilling rig and patch a conductor pipe, or weld pipe together that has line pressures of several thousand PSI are not looking for work. It was tough 20 years ago to hire a machinist that you could draw a sketch on a piece of paper of something you wanted built, and then get it done. It is one aspect of our advancing world that will leave us high and dry. One funny thing to close with: There is a guy here in town, auto mechanic, that had an old truck come in and the ignition was dead. Wow, presto, no electronic brain box, no on board computer...lo and behold, he pulled the distrributor cap off and saw something he had never seen before, and had no idea what they were (really guys, true story), so he had to ask the owner of the truck. Says a lot for our technical training. The school he attended didn't teach that old stuff, so he had never seen point style ignition and had no idea what made an ignition system work. Now my question: Suppose he knows how electronics work? How could he understand the hall effect switching if he didn't know the basics???? ???
jpgreen
Sad story Joasis.
I sat in a coffee shop one morning down south and an older ford tractor truck with a trailer load of steel broke down in the middle of the road.
Watching 2 guys fiddle around holding up traffic while eating my breakfast, I went out and asked if I could help, and they we're clueless. I jumped up and pulled the ditributer cap- found all the contacts corroded.
Wipped out the file on my Gerber, cleaned em' up and she fired right off. These guys had no idea what I did, and were just dumbfounded.
Tried to get a deal on some heavy angle stock from the owner after saving him big bucks on a tow, and he didn't think it was worth it.  Another idiot!..   ::)
Daren
I think Joasis and I could swap stories here about skilled trades. Like I stated I was a third generation pipe welder, I got out of that 5 years ago to start my own business. I have welded on so many tractors, trailers... I have lost a little of my hand for pipe welding. I have made alot of handrail, I subbed through a concrete contractor who was doing TONS of handicap ramps. My Dad is getting ready to retire in April, none to soon. In the few years I did it I even saw the trade change, it was getting more profit driven (who can weld fast, not who could weld good). Guys like my Dad, and Grandad took pride in their work and it showed. I was never a GREAT welder, I stayed employed because I had a master plumbers license, could pass any welding test, and was willing to be foreman on big jobs. I had GREAT welders work for me, but they were my Dads age, they are all leaving the trade. Unfortunatly guys like him are a dying breed. He made EVERY weld his best one, that is not what the contractor want anymore, they want "inches", how much you can do in a day. Kinda bums me out.
simonmeridew
Larry:
From one dobber to another, I'd use an eighth inch 6011 rod at either 90 or 105 amps, take my time so as not to heat the rest of it too much, chip and peen between passes and maybe finish up with a 6013 at 135 amps.
I like the idea of gas welding though limited experience can't recommend.
Good project and it'll turn out 100%.
simonmeridew
etat
Quote from: Larry on February 01, 2006, 11:18:57 AM
Don't ask. :D
Larry.  One thing for sure is if you weld that you want a one hundred percent penetration weld.  I'd grind it down enough to a point where I make the repair and stick it good.  Then I'd chip off the weld and grind it almost off making sure there were no pits or slags in the weld.  I'd go slow and chip and grind the weld after EVERY pass.  It will take a while but eventually you will get it built up.
Next comes the 'most important part'.  You have to reheat the whole thing to red hot and then pack it in something like oil dry to let it cool slowly to equalize the metal.  Otherwise it is prone to break again near the weld whether you want it to or not.  This is called annealing (or equalizing the metal).  Then the piece could be reheated again and re tempered.  I do not know the proper procedure for re tempering something like that and I would recommend you visit a blacksmith forum and ask someone who does.
