Get the Big Blade!
Started by dgdrls, March 19, 2018, 08:35:57 PM
dgdrls
When the the circle blade is feet taller than you
or it takes 2 men and long roller trolley to manage a band
you know you're in the big iron!
D
Kbeitz
Wow... wonder what the kerf is....
Love machine shop work
and Wood work shop work
And now a saw mill work
Ljohnsaw
 :o
Wow, on that big blade, the arbor hole looks pretty small - like 2 or 3" diameter.  Also it looks like that band blade had teeth on the back side at one time.
John Sawicky
POSTON WIDEHEAD
 :D :D :D :D Them some whoppers!
enigmaT120
That bandsaw blade reminds me of the ones at Hull Oaks, a mill south and west of Corvallis, OR.  That's a cool place to tour.
Ed Miller
Falls City, Or
Iwawoodwork
enigma, that room also looks like what I recall of the Hull Oaks filing room, might be their saw.
starmac
I want to see Magic Man coil that baby up, that puppy is impressive.
I tried @starmac but it slipped out of my hand and I got whacked.  At least one of us got "coiled".   :D
paul case
I learned something at the local large walnut mill a couple years ago.
Their saw took big bands like that. The things that look like broken teeth on the back of the band are to clean up the strings on the exit side of the cut. I Think the one in the picture is not a double cut band as they would have the same number of teeth on the front and back. The cleaners on that band look like they are 1 cleaner to every 2 or 3 teeth.
PC
pc
starmac
Oh wow MM, next time that woman tells you to do something, just go ahead and do it.
gspren
  After many years in machine shops I never met a band I couldn't coil, big ones in 5 coils, but I did just see a picture of one I wouldn't try!
Kbeitz
And it you did coil it I would not be the one to uncoil it... No way...
Southside
Does Woodmizer offer free shipping on a box of those?
White Oak Meadows
terrifictimbersllc
I'm with KB, leave it on the mill and get out the Dremel.
terrifictimbersllc
Quote from: starmac on March 20, 2018, 01:36:52 PMOh wow MM, next time that woman tells you to do something, just go ahead and do it.
Around here the nurse would ask you if you feel safe at home.
coxy
that's what happens when you under bid some one on a mill job ;D ;D  MM I'm glad i don't have to pay your comp  :D :D :D
