A buddies misfortune
Started by bushmechanic, April 25, 2012, 10:21:37 PM
bushmechanic
This has to be the most destroyed 353 Detroit Diesel I ever had to rebuild.The crankshaft is broken into three seperate pieces.This should keep me busy for a few nights in the shop.
treefarmer87
i have never seen one that bad :o
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
sealark37
How are you going to deal with the block?  Just curious.
sandhills
Until now, i didn't think you could kill a Detroit, It appears I am wrong.
dgdrls
I bet folks were ducking for cover when she let go!
Any Idea what caused the failure?
DGDrls
red oaks lumber
doesn't that look how detroiters sound :D
Stephen Alford
All i can say is anyone who looks at that and says " I can rebuild it " gets a tip of the hat from me.   8)  8)
logon
DeerMeadowFarm
Quote from: Stephen Alford on April 26, 2012, 08:46:29 AM
+1!  8)
lumberjack48
I have never seen one throw a rod, let alone break the crank. I would have liked to have been there to hear the noise it must have made. Are you sure he didn't run it out of oil. Boy those journal cap bolts must be tough to keep from breaking or pulling the threads out.
If you have all the pieces or piece that broke out of the block, you can weld it back together. I don't think there are any water jackets that low in the block.
That will be a good project, take pictures as you go.
I took a closer look, as much as i can see on the right side in pic, damper wheel side, block might not be fixable.
grassfed
I think that I would just start with a short block or another used motor and save any good extra parts for spares.
Mike
tlandrum
i could hook you up with a nice 353 if you were not so far away.
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
Tramp Bushler
It looks like it must have over sped . Ouch . Well maybe the starter is still good .
If your not wearing your hard hat when you need it. Well.
Okrafarmer
You could weld the crankshaft back together, just enough so you can pick it up, and it would be a really great object lesson to mount up on display somewhere.
Now selling Logrite tools!
bushmechanic
I finished taking her down last night and surveyed the damage.The block has to be replaced,the number two bearing cap was just ripped out of the block and I found it in the basepan.I think it was the crankshaft that was the initial problem,although it was recently rebuilt by the looks of things and the job left something to be desired.The cam bushings were poorly placed and almost had the oil supply cut off to the cylinder head.In the oil galllery to the blower there was a wooden plug pushed in the hole,I assume the blower was leaking oil and this was sombody's fix for that!Anyway the owner just dropped off a doner block and another crank,now I have to order a overhaul kit and a cam bushing kit then the fun begins.
Tramp Bushler
Bush mechanic ; where do you order your rebuild kits from , how much does 1 cost ??
tjdub
Quote from: lumberjack48 on April 26, 2012, 10:29:50 AM
Me too, but only if I was wearing ear plugs... and ear muffs...  over my ear muffs... while standing a couple of hundred feet away :)
bushmechanic
Hey lumberjack48 I had one in a 230D Timberjack forwarder and when it blew up it cracked the number 2 connecting rod in two and the short piece banged around inside the block until it bust holes in both sides of the block and it didn't stop until it ran out of oil.There was a new operator on that machine that day and he never used a forwarder before and you should have seen how far it went on two working cylinders-I could tell by the oil trail on the snow,and it had four cord on it too.Tramp Bushler I get my kits from all over but a good spot is AGkits.com there prices are good and good service too.Usually the price is about 800.00 canadian time I get it here for an overhaul kit.
Tramp Bushler
Ok. Thanks . I need to get the tools for rebuilding 53 and 71 Jimmys . And a book on how to . I sure do apreciate all the info you put on these threads .
kiko
Its been awhile since I fooled with a Detroit.  I seem to recall the only special tools needed were feeler gauges and injector height tool.  I never had any luck with ring compressors, loader the pistons into the liners from the bottom and installed into the block as a assembly. Oh yea, almost forgot about the match stems ,vise grips to control the rack and a clip board.. If you ever built a Detroit then you know what the match stems are for.  Any guesses about the clip board?
shelbycharger400
 it would be currious to see what casting that block was.
the detroits used in the chevy trucks were all thin wall blocks ( chevy pithed about their front suspensions couldnt hold up to the weight of the engine, so detroit went thin wall casting)
some of the thin wall blocks went into other equipment as well.
buddy usto work at a rebuilders shop.  it wasnt uncommon for them to cut bad blocks apart, then reweld in good sections.   he has told me to AVOid detroits due to their thin webbing in the main journals.  he said he has torn down many, when he pulls the pan, a few outside main caps... crank drops out.
i had the welders at the shop hot weld an exhaust manifold for me,  and put on a cast flange from another manifold.  ( it was cracked already too)  it was from my neon dohc. i put a stress relief cut in the flange where it bolted to the head ,  it went to them, they blew it all apart, fixed the crack from the flange at the head to the end,  put in an angled piece from a cat block, and welded my flange on it.   i had to do some final internal grinding..  that guy did one heck of a job.   it was all welded inside a table oven over 500 deg.  with a big oxy/acet. torch!  cost...  case of beer,   rumor is he did it on clock time too...lol
celliott
Quote from: kiko on May 05, 2012, 09:15:06 PM
To put over the intake and starve it of air to shut it down in case it runs away, right?
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
kiko
That's it. I never was a "detroit man
That's it. I never was a "detroit man" . Sometimes repairing a Detroit was part of the job, but those 2 strokes always made me nervous . There is an art to being a "Detroit man" and it is fast becoming a lost art.
barbender
Bushmechanic's buddy's Detroit looks like it might have ran away.
Tramp Bushler
 Ya , I really like Detroits   . That is the engine they put in Nelson Log Bronks . 3+453s , 671 in the big 16 footer . They were the only engine tough enough to take the pounding .
What kind of sockets do I need for 53 and 71 series .?  Than multi pronged / star bolt head .??
Okrafarmer
Tramp, I was in Alaska in 2006. Didn't make it over your way, but I know where your area is. Met someone from there at the time. Anyway, I remember seeing an Allis Chalmers HD-14 dozer in Palmer. They have detroits too. That one would be a 6-cylinder, the HD-10 had the 4-cylinder, HD-7 had the 3-cylinder, all with the same specs. Circa 1939-1947 ish.
