Some Small Tractor Road Work
Started by g_man, October 01, 2016, 06:13:15 PM
g_man
I put in a new tractor road this past summer. I finished it up with a little gravel. Filled a mud hole.
And put in a culvert
I made a removable chute for the tail gate on my one ton. It makes loading the trailer real easy - just dump from the truck into the trailer.
Having fun in the woods during my second childhood  :)
gg
Ed_K
 That's a great idea  8) on the chute. I've been thinking of using an old sander body mounted in my forestry trailer to haul a little gravel at times.
Ed K
47sawdust
g man,
What size is the Pronovost trailer?Any trouble dumping the stone?
Thanks,Mick
Mick
g_man
Quote from: 47sawdust on October 01, 2016, 06:37:26 PM
g man,
Thanks,Mick
It is an older 503 Model - rated for 1.5 ton pay load. The box is about 4' W X 6' L X 1' H. So it will hold a yard. I just bought it about a month ago. My tractor is rated for a 3000 lb trailer but it handles this easily even going down fairly steep grades. This load in the picture is well over 3000 lbs. I had 6060 lb (3.03 Ton) of 3 1/2" crushed road base on the truck and emptied it with two trailer loads. The second trailer load was small, below the sides at the high spot. I was a little slow on the truck dump switch on that first load. I brought a shovel just in case but it dumped just like it was empty.
gg
Good idea on the truck dump body. I hunt the stone walls for small rocks. Most times big ones go in first,than the smaller ones.
BurkettvilleBob
You've got a fine public works department there, easy way make a DIY culvert too. I'm amazed that trailer dumped that load. I looked at the same model last year, it was over in the "as is" department at the local tractor dealer. I wasn't sure how useful it would be, and the price was high for the amount of tinkering it needed. I'll definitely consider one more seriously next time.
I also wanted to ask when I should expect to be able to start my "second childhood"?
timberlinetree
Nice job! That trailer looks handy.
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
