JD 440a axle planetary question
Started by thumper, September 05, 2010, 01:11:34 PM
thumper
hello everyone.. im  reasssembling my inner/outer axle bearings, seals, thrust washer and new axle/planetary bolt on my 1970 440a.  i blew my outer front axle bearing thursday and all you jd guys know the proceedure on this! lol.. does anyone know the torque spec for the new axle/planetary bolt and the 12 axle housing to differential housing bolts? :P
Jonsered 2150 2152 2156 2165  Husqvarna 262xps Worn 1970 JD440a 06 GMC 3500 DURAMAX
dnash
According to 540 manual:
axle housing to differential case - 130ft/lbs
Tighten planet pinion carrier bolt to 115ft/lbs then rotate carrier 3 times and tighten to 125ft/lbs. Install lock plate (triangle plate)...may be necessary to flip. If planet pinion carrier bolt must be turned for alignment, do not advance more than 8 degrees.
Hope this helps.
JD 440C
JD 640D
Timberjack 205HR
JD 329E skidsteer
JD CT322 skidsteer
thumper
thanks for the quick reply!!:)  is your manual for the strait 540 and 540a?
dnash
Its for the 540 (no extra letter). I assume the 540a will be very similar in terms of torque specs etc.
JD 440C
JD 640D
Timberjack 205HR
JD 329E skidsteer
JD CT322 skidsteer
