check engine light
Started by coxy, September 10, 2015, 03:45:00 PM
coxy
can you take a road test with the truck if this light is on
LaneC
   What do you mean by a "road test"? If you just want to see if it runs ok., you should not have a problem. If you want to see what is wrong, and why the light is on, you can bring it to Auto Zone(if you have them by you) and they will tell you what the code is, and can sometimes clear it. The check engine light on my truck has been on for about 5 years now and it runs fine :D
Man makes plans and God smiles
sprucebunny
In many vehicles, the light being on will mean the computer is in "default mode". I've had the light on for the oxygen sensor for years and never noticed a difference in anything.
Getting it inspected is another story.
coxy
road test as cdl  put a new motor in it and the light wont go out took it to 2  dealers and they have no idea why its on
sawguy21
They likely won't let you take a licensing test if the vehicle has obvious defects.
Warped
If it's inspected and registered I do not believe you'll have a problem, especially considering obd is for emissions not safety. It could be something as simple as a previous misfire.
Good with the rough stuff and rough with the good stuff
brendonv
I remember when I got mine the class b guys were going over the straight truck with the tester. She failed it because of a cel amongst other things. Pretty sure it's gotta be perfect.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Chuck White
I don't believe that they (the "brownie") would allow any of the instrument panel lights to be on!
Ford_man
I put an extra tank in my small pickup and they are vented together so when both tanks are low it takes too long to build enough pressure in the tanks and will set the check engine light on. i have my own OBD scanner so I can reset it my self. It would be the same as not putting the cap on tight enough.Technology is wonderful(ly stupid) smiley_tom_dizzyguy01 smiley_tom_dizzyguy01
Is the check engine light a bulb that can be unplugged?
Banjo picker
Lynn you think just like I do.   ;)  If the officer sees it I bet the deal wont go down.  Banjo
Pine Ridge
Magicman i believe they are a bulb that can be unplugged, might be hard to get to though.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
sawguy21
We  covered them with electrical tape but that might be noticed.
kensfarm
Pull the positive off the battery for 5 minutes.. that should turn if off for a while.  We have emission inspection in MD.. can't pass if check engine light is on.
Warped
     I wouldn't extinguish the light too far in advance, once the system goes to closed loop the monitors will run and possibly/likely trigger the light.
     My F-250 will run a little rough at first on very damp days after it sits awhile, sometimes it triggers the CEL for p300's code which is for misfire (ex.305 is cylinder 5). Hope you don't have an evap code, they can be a nightmare!
I use an Innova scanner and am pleased with it for a 100 bucks
coxy
sprucebunny
Maybe showing the reciepts from the dealers will get you a pass ???
I was not advocating disabling or sabotaging the system, just trying to figure out a way to extinguish it for the driving test.
auusie joe
coxy
 :D :D today DMV told me it was not safe to drive  :D :D :D :D :snowball: :snowball: :snowball:
Warped
Good grief, could be a loose fuel cap.......in NY they figure it must be a potential road bomb. Of course we'd know with the code :D
A lot of deaths from bad O2 sensor also, real dangerous........
coxy
the sad part is its not showing a code  ??? ??? ??? ??? ??? ??? ??? ??? ???
21incher
Quote from: coxy on September 14, 2015, 06:59:59 AM
If it is not showing a code then there could be issues with the computer or wiring? I understand if you reset a check engine light in NY you have to log 500 miles on the vehicle before it can be inspected.  :)
coxy
we only do 50 miles and good to go
