Building a DIY Homemade debarker for my Woodmizer LT35HD
Started by MikeySP, February 23, 2019, 12:08:28 AM
MikeySP
Ga Mtn Man, thank you! It may have been a much better use of your time. I am glad I have it and there is no way I would have gotten one for a few months otherwise.
I can't believe I did not think clear enough to see that. I have had some cuts, especially on dirty logs with no bark, where the blade was just north of the triangle shaped kerf and instead of asking myself, "what is the solution?", I thought, "bummer, I guess I need bark and maybe a little debris sand blasting is cleaning some of it." I will be making that adjustment today of blade to the southern edge!
Big thank you sir!
-Mike
MikeySP
Almost forgot. But, I want to help anyone else keep their ship afloat and on azimuth if they embark to debark :)
The bicycle crank works and pretty well; however, I would go with the appropriate hardness shaft for those lateral forces and some good sized sealed bearings inside a thick walled steel tube that has some bearing recesses turned on a lathe. I have seen the debarker under certain conditions (not sure what they are yet) chatter up and down along the cut. I may do as Tom the Sawyer says soon and setup a camera to film all, and I will share it with you as I try to learn to cut better and perhaps have clarity to see what is the cause of this occasional chatter. So, I am only putting this here in case it is springiness in a bicycle crank. If this is the case, I will use it as is for at least several months, but once I have a shop on my property, I will make a few mods and this may be one of them. Would be fairly quick.
I will take out some time today to mount the factory springs and see if that alleviates the great tension I feel on the handle and perhaps that will take away my perceived need to extend the handles or add a gear motor down the road.
Have a great day!
-Mike
MikeySP
BTW, Southside Logger, in answer to your inquiry: "the lingering question is did you remember to lower the toe board after that cut or did you end up making long wedges in all the excitement?"
I know nothing.... However, I was delayed in responding because I had taken a photo of this long and pointy board that someohow showed up after that... but apparently I did not push the photo button and it did not take. So all evidence is gone and you can't prove a thing  :D
MikeySP
Factory springs are much more user friendly. Allows gliding over edge without digging and much easier to pull handle. Negative side is it does not allow max arc. So, on a small log, I need to move the chain a few teethe on the sprocket. If a radical difference between logs occurs such as 28", 10", it would be a headache. If I motorize it, this problem disappears. For now... very satisfied, but I will plan on a gear motor in future. Factory springs were spendy. If, when I make any changes, I will update.
Ljohnsaw
We (I) need to see the whole picture of where the springs are in relation to your ratchet thingy.  For quick adjustments for different sized logs, could you make up an over-center like link where the springs attach to the saw head?  Like what is used on chain binders.  So, for a small log, you latch the inside one and unlatch the outside one.  Opposite for a large log.  Or maybe a disk that you can rotate (like a sprocket ;)), and set to 2 or 3 stops for small, medium and large logs?  The disk would be attached to both springs to simultaneously tighten and loosen the pair of springs.
MikeySP
@ljohnsaw  , I am very sorry I missed your question. I think I may have read it while traveling on my phone and forgot to answer when I got home. I just decided I needed to visit this thread and give an update when I noticed your question. BTW, If I ever fail in the future, don't hesitate to PM and say, "hey deadbeat, answer my question!" :)
I am going to run out and take some photos. I will take off the cover too, so the sprocket is easily seen. Indeed there is a problem with different sized logs. I did two days of sawing for a fellow this last week, a little over 1700 board feet and I am VERY happy with the debarker, overall. I think I tripped the breaker twice, by having too much tension, when the log got wider on the far end. He had a lot of different sized logs, so I had to slip my chain about 3 or 4 times during the job to accommodate them all. Once I took off the cover to do it once, I left the cover off to speed up the process, about 30 seconds. I also, just sawed in a few circumstances and let the sawmill blade eat bark. A curved log is narrow and wide depending on orientation, so this was a problem too.
If you had a slip pin that quickly adjusted it to differing sized logs as you propose, small, med, large it would work well I think. However, here are a couple other ideas: One, use the smallest sprocket of the three on the bike. This will give more movement for less area and the added benefit of more leverage against the springs, meaning that it will be less likely to trip a breaker as the saw blade will more easily push away from the log without digging into it and overloading the amps on the breaker.
Personally, I think it would be great to just add a 12v geared motor with decent duty cycle ability near the saw end of the debarker horizontal support. This will operate as a "winch" if you will and all is needed is a momentary reversible switch and a relay to get it done. I am going to keep it all as is for now as it works pretty good and I do not like having to drive across town to work at friend's shop, slow to get anything done. Once, my barn/shop is up, I will have my welders, etc.. setup and I will probably grab a smaller sprocket, off  junk bicycle I have and exchange sprocket. That will be a quick and easy solution I think. If that fails me, I will pull off the hand mechanism and put on a 25W (1/30 HP) 12V geared motor. I will do some simple math the determine speed of opening/closing. MAY need to add speed control, but I don't think it will be necessary of I do good math.
I really think it should all be controllable from the operator location rather than going around head to adjust a pin.... if you are in a production environment. Especially since it is an easy thing to resolve... in my mind anyways :).
Hilltop366
Nice work.
I know little about debarkers but I was wondering if some sort of guide or shoe on a bracket just below the blade to control depth of cut would help to prevent over loading the motor. Perhaps a disc a bit smaller than the debarker blade on a bearing?
MikeySP
Thank you and good point Hilltop366. Actually, woodmizer has such a disc spacer that actually mounts right next to the blade to control depth of cut. It is just a really big washer in essence. Thanks for bringing this up. Perhaps, I will spring for one when I order some other items. However, it does not solve the different sized logs, so I almost see it as of no benefit. The depth of cut, seems to be easy to control once you get used to the appendage (debarker) addition. The challenge is when it won't reach the bark (small log) or you need to adjust the chain location to accommodate a large log with the efficiancy benefit of doing right from the operators location. The cadillac way is with a simple momentary reversable switch. Next up and probably a good fit for an LT35 (already is a manual blade guide arm and drive built mechanisms). I do not see tripping breakers as an issue for me at this point. Perhaps an occasional problem when I lose my mind.
MikeySP
MikeySP
12V Geared motor optionI would probably do if I was starting over. Just need to wire it with a momentary reversable switch and a relay. A relay takes a very small amount of power to flip a switch on or off. So, you can use SMALL wire to flip the witch for bigger wire/power.
Hilltop366
Quote from: MikeySP on April 09, 2019, 10:13:08 AM
Your welcome.
I see now what you are saying about the log size problem.
Would a smaller sprocket increase the range of motion per travel of chain, or does that present other challenges?
MikeySP
Hilltop366, I think the smaller sprocket may do the trick. The bike had 3 sprockets and I used the middle size because I only knew to do distance traveled math and did not account for spring stretch. I am sure there is a limit to how small I can go, but that third sprocket will likely help in both extra swing arm travel and lower the likelihood of tripping a breaker.
