How to file a chain
Started by dsgsr, January 16, 2009, 06:42:45 PM
dsgsr
Where can I find info. on filling different chains, how too guide?
Thank you,
David
Northlander band mill
Kubota M59 TLB
Takeuchi TB175 Excavator
'08 Ford 550 dump
'87 International Dump
2015 Miller 325 Trailblazer Welder/Gen
GASoline71
\"...if ya mess with the bull... ya gets the horn.\"
TreePointer
dsgsr
Kubota M59 TLB
'08 Ford 550 dump
Frickman
If you are using Stihl chain most of it has little etchings on the teeth that mark the proper angle and hook for the cutter. These marks still come in handy for me and I've been filing saws for decades.
I've got a square and a round grinder but still file too.What I do is clamp the saw and bar in a vice file away for half the cutters then turn the file around and pull it to me for the outhers, anyone else do that or am I the lone ranger,works good for me.Frank C.
Tom Sawyer
Quote from: bandmiller2 on January 23, 2009, 03:28:19 PM
I do something similar, except that instead of pulling the file towards me I turn the saw around in the vise when I am done the one side.
LeeB
I do both, however i mostly do it like Tom does. I find I can get the teeth more even in length that way.
Larry
What Tom said.
It's a great way to learn.  Put one hand on the handle and the other hand on the file end.  Concentrate on making the perfect stroke with correct angles.  Once you learn the technique in a vice makes it a lot easier to do out in the field on a snowy day with the wind a howling.
Another tip...how do you know iffen your chain is really really sharp?  Drop the magnifier with light and take a good look see.  If the chain is dull the light will be reflected off the edge and it is easy to pick up, even for 60 year old eyes.  I can drop the magnifier over a chain on the grinder also.  This magnifier is permanently mounted to the work bench.
Got another floor stand magnifier I use the same way when I sharpen bands, drill bits, or what have ya.  Sharp stuff seems to cut better for some reason. :)
Piston
Not really a complete how-to guide, but i found the Carlton write up extremely helpful as far as understanding WHY i'm filing a chain the way i am, you may want to thumb though it for some decent diagrams.  its in the forum extras under "knowledge base" the go to the chainsaw section and you'll find it there.  i actually feel confident sharpening my chains after reading it a couple times, as well as reading all the tips everyone gives on here.  hope that helps and good luck
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
capt n cutz
Now, if there was just a vise out in the woods!  I can think of a dozen guys I know and have seen file...none of them the same way.  Once it is understood what has to happen, hide from everyone and find your comfort zone and what works best for you.  I can suggest practice on the ground, a log, or a tailgate, something that is always handy, cause they don't get dull in a heated garage with a vise all the time.
I've been hooked on the sweddish roller guide for a little over 3 years, must be I like it.
So...You want to be a Logger? eh!
dsgsr
Thank you all for the good info. I guess my question was a bit vague. I can sharpen my chain saws with regular cutting chain (round or square chisel round ground) well enough Although I can always learn a thing or two. I've just recently come across square ground and am not that familiar with it (and don't want to be). I was looking more for the different types of chain for ripping and such. I've been thinking of getting an Alaskan Sawmill or something down that road and have never seen how rip chain is chiseled or sharpened.
David
Kubota M59 TLB
'08 Ford 550 dump
John Mc
Quote from: capt n cutz on January 25, 2009, 04:49:38 PM
I've gotten hooked on using a stump vise. Just pound it in to a handy stump or log, and you've got something that holds it as well as a benchtop vise. In fact, I use my stump vise for filing at home as well... just pound it into a 2x6 and clamp that into my workmate/sawhorse.
Larry,your right,I do the same thing if you can see the cutting edge its dull.The sharp edge on a cutter will disappear.Frank C.
missourilogger
i do that
i Was here
and here
