Is elm worth sawing?
Started by bakerhardwoods, June 01, 2013, 10:30:08 AM
bakerhardwoods
I have some elm logs that are decent diameter and I'm wondering if I should have them sawn or haul them to the pallet mill.  They are just plain logs, about 18 inches on the small ends without many branches.  I will for sure take the smaller elm to the pallet mill. The boards should be fairly decent.  I sell wood some and have not had anyone ask for elm.  I already have some elm that i haven't sold.  Also, I have not used much of it myself.  I generally say that my problem is that I haven't seen a log yet that I didn't like, but this can get expensive.
The tree ID forum seems to think this one is elm and I'm sure some others are, but I didn't think elm had white sapwood.
Chuck White
If you need planks to load implements onto a truck or trailer, elm would be a good candidate.
Used to be sawn and used for replanking the floor of horse stalls!  Held up well with the urine, etc.
It's a strong wood and straight grained.
I had one given to me and I sawed it early last fall, still green, I didn't get a lot out of it, but I have 2 nice 2x8x12 planks now!
barbender
Yep, planking. At least that is what it was used for around here. Unfortunately, we lost all of ours that was sawable size to Dutch Elm disease 25 years ago. All we have are saplings ::) Bur Oak is the back up species.
Elm is a useful wood for woodworking.
Main issue is that it twists and warps a bit as it dries. Usual plan is to saw it a bit oversize so you can plane out the movement.
BUT, whether it's worth sawing depends on local markets. Doesn't matter how "good" the wood is, you haven't made anything until it's sold...
Tried advertising a "packet" of it for a good price? Might get some takers that hadn't considered the option of using it?
mesquite buckeye
Can't get mine sold, so I make furniture from it. It is nice.
I think it has been out of the market for so long that people forget it has been used successfully for woodworking for forever. It is reasonably strong and attractive. Bends well. Forest grown trees seem to move around less during drying than yard or wolf trees, but you need to sticker them well if you want to get anything worthwhile.
Woodkiller
It is fun to turn. I have had decent luck with it.
Remember the old pickup trucks from back in the 40's and early 50's most of the wood beds were elm. Frank C.
Chuck White
I remember the old wooden bed pickups, but I didn't know they were elm.
Learn a lot of new stuff here!  ;)
The spiral grain makes it shock and split resistant.  I have heard that it was used for wagon wheel yokes.
Dewey
i had an Elm log given to me years ago.....   I sawed it  out all 5/4  450 BF worth....  I showed it to everyone that came into my yard . I finally had a boat builder ask if he could buy 1 board...  He  took it home planed it and put a finish on it, called me the next day and wanted it all  !!!!!  I sold the whole pile for $2.50 a BF !!!  Not a bad payday for a free log  !!!! 8)
francismilker
To answer the question is it worth sawing, I think it is.  I sawed some and then put it in the barn to air dry 6 months ago.  It's still as wet as it was the day I cut it.  As far as trying to drive a nail in it, just say "NO".  The stuff is springy and definately shock resistant.  I'm not sure if there are any oil drilling rigs in our area that don't use elm for cribbing/leveling blocks.  It's abundant around here and faily easy to saw.
I had no clue it was used for the wood in the back of the older pickups from yesterday.  That's interesting.
"whatsoever thy hands finds to do; do it with thy might" Ecc. 9:10
WM LT-10supergo, MF-271 w/FEL, Honda 500 Foreman, Husq 550, Stihl 026, and lots of baling wire!
barbender
I remember trying to split some of the dead standing elm, that was the gnarliest stuff I ever came across. You couldn't split it with a maul, the best you could hope for was knocking the outside rings off so you could fit it through the door of the OWB. There was no way it was splitting down the middle. Gnarly stuff I say :o
barbender
That is when I make one or two additional chainsaw cuts "down the middle" will knock them down to "door" size.
As quick or quicker than splitting... just lose some chainsaw chips.
SPIKER
Around here there are still a few standing (I have a 2logs on a trailer now) as said planking (heavy as heck tho.)    The logs on the trailer start about 24" at the but and I got 2ea 9' logs out of the middle of the woods.   It was standing dead for about 3 years now & bark just came off after felling.
Was used in barns as flooring a lot (both lofts and under hooves) as it is somewhat rot resistant or at least it holds up to manure/urine well...   Also was used as stall walls for same tendencies of strong & resists cribbing.
Elm will give you fits to split for firewood but it burns like coal,low flame and glows red.I've only got a couple left on my property DanGed dutch elm got most of them. Frank C.
NMFP
Most of the old ice boxes from years ago... late 1800's used elm as the interior liner because bacteria growth.  Elm naturally prohibits bacteria growth and that's why it was used to line the inside of ice chests and boxes...  some early refrigerators used it as well for shelf material and shelf supports.
John Bartley
This resistance to bacteria growth, along with its incredible toughness (resistance to knife cuts), as well as the lovely grain figure, are the reasons for using Elm as cutting board material.
John
Quote from: NMFP on June 02, 2013, 08:16:46 AM
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
ET
Great thread!  I've got a lot of live and dead elm as well. Now that i know it is worth sawing and when I get ready to sell some I will know its potential uses for telling future customers. Thanks FF!!!
Lucas 1030, Slabber attachment, Husky 550XP, Ford 555B hoe, Blaze King Ultra, Vermeer chipper, 70 acres with 40 acres Woods.
DaleK
Makes great workbench tops too once it's dry, grandpa's old work table is 3" thick elm, can't dent it with a ball peen hammer. He built a 34x70 addition on the barn in the 50s when Dutch elm first went through here, completely framed with elm.
Hud-Son Oscar 330
Wallenstein FX110
Echo chainsaws and a whole bunch of tractors
NMFP
That's interesting you say framing with elm because I am currently sawing a barn package for a guy that is using almost dead ash.  its a 60 by 60 bank barn with total height of side walls being 44' high so its not a little barn.  Only 2 species going into the barn... almost dead ash from Emerald Ash Borer and Hemlock almost dead from scale and wooley adelgid!!!!  I hope were almost done with loosing our different tree species!
mesquite buckeye
Discouraging. They will still be around, but die before they get big.
Okrafarmer
I've found that the secret to selling unfamiliar species of lumber is to just get people in the door to look at something else. Then show them everything you have. The fact that you have something unusual will spark the curiosity of at least one woodworker out of 5, and you get to sell some of your odd-ball stuff. Even if you don't sell much, the fact that you have so many things available is a plus in the minds of customers who keep coming back to you for the more regular stuff.
Now selling Logrite tools!
Bibbyman
We have two different elm.  Red elm pictured above and every other elm.  Red elm is very different than Dutch elm or elm by other names.   The red elm is very decay resident and strong - more like ash.  Has very little sap and we find it deep in the woods.  Not at all like the field edge or yard elm.
Sawing since '94
Quote from: Okrafarmer on June 02, 2013, 02:01:13 PM
Good strategy.
People wont come and ask for a species that they may not even be aware of, and have never thought of using.
But having some finished samples on display might catch the eye of someone, that had never considered using it otherwise.
Even if they don't buy it then, they now know you have some, and you might have planted the seed for a future project.
mesquite buckeye
Thanks Bibby. Good call. I can't keep any red elm in stock, as the extended family uses it all up before I can touch it. That is much prettier than American elm.
