PH260 shear pin
Started by teed, November 14, 2016, 11:37:01 PM
teed
Hello
Have you had broken shear pin in the era planer? I made a film about how easy it was to replace. I was a bit curious how common it is that it goes broken. Talked with several who have had a PH260 for several years without problems. wondered if I just had bad luck or if I did something wrong.
https://www.youtube.com/watch?v=XhpBn7rRGXI
On my homestead, I mill with.
Logosol B1001 bandsaw mill
Woodland mill HM122 bandsaw mill
Logosol F2 with Speedsaw E5 chainsaw mill
Logosol Farmers with Stihl MS391 and MS661
Tullivor
I have not had a shear pin break but I have noticed oil drops on the floor beneath the feed motor?
WLC
Nothing to add other than I like the music you choose to put in your videos.
I would like to ask a question though.  How much, if any, planer snipe do you experience with your Logosol?
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
teed
Quote from: WLC on December 05, 2016, 05:43:33 PM
I get the music from http://incompetech.com/music/royalty-free/  :)
Do not get anything at all if I adjust everything as it should be. If I get snipe at the end of the board it is because the knives stick out too much in the upper cutter. Setting the fence wrong, you get snipe at the beginning of side cutter
