kiln temperature questions
Started by Joey Grimes, December 05, 2016, 06:31:43 PM
Joey Grimes
I loaded about 600 bf of air dry 9/4 maple slabs set dB 110 wb 98 after 24 hr it started removing water for a few hours then the temp went past 110 the power vent turned on lowered temp now I can't get compressor to run without raising the dB temp ??
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Den Socling
Sounds like you ran out of free water and will need 120+ to remove the bound water. If you were getting water out at 110, there was some wet wood in that predried wood.
