Replacement Caulks Wrench/Socket
Started by THPtech, March 06, 2008, 07:56:17 AM
THPtech
I seem to remember running across a caulk socket that fit on a 3/4 rachet. I have a nice wrench but I'm always lookin for trick little things. Does anybody know where I can find one?
Welcome to the forum. Hope you pull up a stump and stick around.  :)
Caulk to me is oozy material shoved into cracks to seal them up.
Not heard of a caulk wrench....but maybe you have something else in mind, or I'm just not tuned in..(dat happens   ;D)
johncinquo
Baileys has em.  I think they're on sale in the new catalog.
To be one, Ask one
Masons and Shriners
Kevin
There are many calk wrenches available but I'm not aware of a calk socket for a 1/2 or 3/4 drive ratchet wrench.
3/4 seems a little excessive.
sawguy21
 :D The t-handle is quite adequate.
arojay
Well,  if a guy had a lot of caulks to replace, he could cut off the handle of the t-wrench and use it in a 3/8 drill.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
ibseeker
beenthere, I think the caulks they're talking about here are the ones that loggers use when working on floating logs.
The key phrase here is "I think"......maybe someone else will clue us in
Chuck
worn out poulan, Stihl 250SC, old machete and a bag of clues with a hole in the bottom
THPtech
Holy crappola 3/4 is a little big huh. Ha. My bad, I meant 3/8.
Forum: 1
THPTech: 0
Quote from: ibseeker on March 06, 2008, 11:40:47 AM
I think you are right...I missed that and did know about caulked boots.  ::) ::) ::)
Tillaway
Wesco's need an odd ball wrench kind of like a socket.  Every one else uses the two pin type.  I had one T handle wrench where the handle would slip off and you could chuck it in a drill.  No more buggered knuckles, I always hated replacing corks.  Too bad i lost both wrenches, I have been suffering with nubs for quite a while.  I really need to find one of those wrenches.  The one with the plastic T handle that comes off is the nicest I have found.
Making Tillamook Bay safe for bait; one salmon at a time.
Paul_H
Tillaway,
remember the pound ins? I used to replace some peoples pound in caulks for a 12 pack.Had a last,puller and a driver and used cedar or old shoe lace to shim.My knuckles took a beating when pulling out the old worn out caulks. :)
Tillaway
Paul,
Yep, had a pair of Buffalo Fly-wieghts.  Up until about 2000 or so there was still one old boot shop that was using them down in Roseburg.  Apparently they had quite a stock of them or were making their own.  I never replaced them myself, I sent them to the shop.  About the time I started to shed them it was time for new soles anyway.  I still have the boots rebuilt as corks twice and vibrams twice.  I finally wore threw the leather on the curve by the instep and the boot shop said that was all I could get out of them.  They did patch the hole though.  Anyone want a "slightly" used pair... cheap.  ;D ;)
