General Forestry => General Board => Topic started by: Magicman on February 15, 2018, 07:33:02 PM
Jeff now has the Member's Map up and running, so I would encourage everyone to check their pin for accuracy and let's use the map. Click on the Satellite view and zoom in tight with the + and you can actually place your pin on your rooftop.
Yea, a lot of you are goona drown if you don't move your pins! I'm guessing they were placed without zooming in on the map to do so, so they were way off.
I just did a little more tweaking to the format of it now that is is running, so when you click on a name in the right column, you will see the profile info better, and can click and go to that profile.
I had to fine tune my map pin. In Map mode, it was right on my house, but in Satellite mode, it was on my neighbor's house. So now, the pin is in the top corner in Map and bottom corner in Sat.
A short video tutorial on how to accurately place your pin on the members map. Remember, the map is only available to members.
Setting your location pin on the Forestry Forum Members map - YouTube (https://youtu.be/xJb2pIVq4L0)
