nail puller
Started by xlogger, September 28, 2014, 07:39:20 AM
xlogger
Looking at some nail pullers on amazon, just wondering what works best other than a cat claw and hammer for getting nails out when you cut the logs? What do you guys use that works well and faster?
slider
I found one on ebay that was better built than those on amazon for about 30 bucks.It was the same style.The jaws seemed to be better on this older tool.
al glenn
DR_Buck
This is what you need.
There was a thread that talked about this some time ago:
   https://forestryforum.com/board/index.php/topic,16303.msg237728.html#msg237728
backwoods sawyer
I have a whole toolbox full of just metal digging tools ;D
A nail puller like shown is in there,
But the handiest is a roll of sharp chisles, take a 1 1/2"  chisle 4 whacks and now you have removed a 1 1/2" square chunck and can see what you are dealing with. Vise grips and chanel locks are the next choise at that point as they will roll nails right out.
Also a long heavy screw driver that has a metal butt plate designed to be used with a hammer works if you have to dig deeper.
Keep an assortment of hammers in there as well from an 8 oz to a 3 lb
And then there is the chainsaw for the heavy metal logs ;D
Backwoods Custom Milling Inc.
Chuck White
I use a hammer and screwdriver to cut a divet around the imbedded nail, screw, etc, then I clamp onto it with a pair of vicegrips and pull it out!
I have one of those slid hammer nail pullers they kinda work on a lot of nails. I have a large pair of end nipper pliers that works better, clear a hole with an old wood chisel grab the offending nail and pry it out. Frank C.
Red Clay Hound
I use a hammer, a 3/4" chisel and a big pair of vice grips.  It gets about 90% of the nails, screws, etc.  Unfortunately, I have had a lot of experience removing nails from logs! taz-smiley
2007 Wood-Mizer LT40 Super Hydraulic with 51 hp. Cat; 2007 Wood-Mizer EG200 Twin Blade Edger; Woodmaster 718 Molder/Planer; Stihl MS460 and MS362 Chainsaws; 2011 John Deere 5065 with JD 553 Loader
Brad_bb
Funny you bring this up now.  I am getting ready to make a video on nail pulling.  I'm de-nailing some old hardwood timbers and they have a variety of nail types and sizes.  One of the worst is the brittle ones that the shank snaps when you try to pull it.  Some heads are so weak they just crumble.  Good quality nails are easier to pull- strong enough that they pull without deforming much, but soft enough so they don't snap.  I think you'll be interested in the different techniques I attempt to document and some tools that perhaps not everyone has seen or had experience with.
If anyone wants to detail some of their techniques, I'd love to find any that I am not aware of to add to the list.
  For de-nailing timbers, my goal is to do as little damage as possible to the timber.
fstedy
I have to agree with DR Buck thats the best puller for nails and staples. You can use the sliding handle to hammer the claws down around the nail and then extend the handle for extra leverage. Vice grips work best for screws and lags. You can't go wrong with one of these.
Timberking B-20   Retired and enjoying every minute of it.
Former occupations Electrical Lineman, Airline Pilot, Owner operator of Machine Shop, Slot Machine Technician and Sawmill Operator.
I know its a long story!!!
backwoods sawyer
Have to agree, thanks DR Buck for bring this old post "Handy sawmill tricks or things I've just come to know" back up.
https://forestryforum.com/board/index.php/topic,16303.0.html
Peter Drouin
If the head of the nail is not right on top I use the nose of my chainsaw. Make a square and pop it out. Sometimes the customer has square holes in his lumber. :D
A&P saw Mill LLC.
License NH softwood grader.
FarmingSawyer
The old pincer/lever style nail pullers are good....the sliding handle means you can ram it into the wood and let the pincers dig under the head of the nail....in carpentry I use one when I am trying hard to do less damage than with a cats paw. But I second the vise grips!! Nothing grabs and levers out nails like them, and they're fast once you get some grip. The pincer thing can cut the nail if you don't get it just right.
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
woodmills1
After using a chisel as mentioned I get most of the cut off nais with a pair of wire cutters, but you need strong hands.  If they fail it is vise grips.
A cordless drill is always with me.  Drilling a hole(s) will loosen the imbedded nail.  Sometimes it takes several holes, sometimes not.
redprospector
Quote from: DR_Buck on September 28, 2014, 08:48:09 AM
My Dad had several of these in his shop. He called them "crate openers", I think his were Stanley's.
I wanted to say thanks because your post made me think of them, which made me think of my Dad, which is always a good thing. I used to have one of Dad's "crate openers", but I couldn't think of where it would be...so I got on eBay and bought another one. It's not his, but it'll do until I remember where I put his.
Thanks again.  smiley_beertoast
customsawyer
I use most of the things listed here. The only thing that I use different is a shingle hatchet instead of a chisel.
www.thecustomsawyer.com
ScottAR
I do lots of interior demo on houses and have several ways.  Pry bars of several lengths... Nippers, Channel lock style pliers, Vice grips, wood chisels.
If any of the nail is sticking out I grab my nail pliers.  Found them at my local Ace hardware.  Crescent Brand #np11.  They have a round foot on one side to pry against and the pull action is directed up.
If pulling finish or headless nails out of trim or thin wood,  Pull them through the from the back.
Makes a small hole on the finish side that's easy to fill vs. a jagged mess.
Scott
[Magicman]
mesquite buckeye
I would add a good, sharp floor chisel to the tools already mentioned.
Tom L
my best technique is I just keep cutting the same log and ruin a saw blade, because most of the time I can't hear the nail cutting or see it until I pull 1 or 2 boards off.
then after putting on a new blade, I drop down a couple of inches and cut off the other end of the nail that I thought would only be a 1-1/2" down in the log.  :new_year:
I will say I have used a chisel and they work good. I have 3 or 4 that have nice grooves in the end after striking said nail. 8)
