WM log loader velocity fuses
Started by Ga Mtn Man, October 02, 2014, 05:55:34 PM
Ga Mtn Man
Does the LT40 SuperHD use the same 5.0 GPM velocity fuses on the loader arms as the standard LT40HD?
Sixacresand
GMM, sounds like a good question for the WM guys.
MartyParsons
terrifictimbersllc
Yes, part # 015832, 5.0 gpm, bought a backup set for mine some time ago.
delvis
If you get in a pinch you can use straight fittings to get by.  Bear in mind they will NOT have the safety feature the fuses have built into them should you blow a hose.  I ripped both fittings off the rams last winter when the became frozen in the snow and ice and I tried to move the loader.  I put straight fittings on from the local Tigercat dealer to get me through the job.
If I never saw another board I will at least die happy having spent the last few years working with my dad!
