posted pictures of my sawmill construction progress
Started by bruce29, January 15, 2011, 01:19:20 PM
bruce29
I have been reading here & working on building my own sawmill for awhile now. I like to see other peoples projects so I thought I would post pictures of what i have done so far. I have somee more pictures that I have not got posted yet. My pictures are im my gallery, have a look & give opinions on any improvements I could make .
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
terrifictimbersllc
Very impressive.  Must have been exciting to put that band on the first time.  Also nice to see that RJ42 just sitting there waiting. Is it going to be mobile?
bruce29
Yes it will be mobile . Going to start on yhe hydraulic log handling parts next week. I am not familiar with hydraulics , so hoping to ask lots of question on this forum.
b dukes
Looks good so far.   I want to build a bandmill when I get finished with the circle mill I am working on now.
buildthisfixthat
 8)  thats one hell of a nice heavy duty saw nice work .when is the first log cut ? the only thing i noticed is the belt tension assembly its not spring loaded .may cause belts to slack under load and stretch quickly as with a loaded tenision assembly will compensate for slack....keep us posted sir
shop built bandsaw mill
Hilltop366
Kind of wondering if you are making any progress, your saw head lay out is similar to what I have drawn out of a possible build idea, I was trying to figure out how your blade tensioner works.
bruce29
my blade tensioner side is basiclly a hinge assy. the tensioning device is basiclly a pipe with a a force bolt pushing against a spring inside the tube that pushes against a plunger assy that protrudes through & pushes against the rear hinge plate.
bedway
If i understand your tensioning does that mean that that pulley will pivot? If thats the case, you might have difficulty keeping your band parallel to your bunks.
Bruce,I'am impressed with your build especially with your frame.The double hinge is the same setup I used on my bandmill it moves such a short distance to tension the band it dosent affect the level base to band the guide roller handles it.I see your using an idler pulley as a clutch much cheaper than buying an expensive clutch,an overcenter that is adjustable is the best I've found.The two "B" series V belts should be enough.What are you planning to use for wheels on the saw head? Make everything heavy and make everything adjustable. Frank C.
bruce29
the arc of the whhel during tensioning is very slight. I was concerned with it when i first started looking at ways to tension the band, but after trying it it works great. any slight change in the band alignment is easily compensated for by the guide roller. I have more pictures that I haven,t got posted in my gallery. I will try to update soon . I have made alot of progress lately.
Bruce,one thing I noticed thats quite important, the guards you built to cover the wheels should be wood or lined with wood if you have the clearance.As sure as the dawn will break  a band will come off the wheels and hit the inside of those guards.If the inside is a soft material it won't hurt the band teeth.I made mine from plywood being carefull where to locate screws,there are several grooves cut on the inside of the guards.Guards should be easily removable to help changing the band. Frank C.
bruce29
As of now my blade guards are all steel. I may line them with a thin flexable plywood inside.My guards are hinged in a manner that allows the whole wheel & bearing assemblies to be accessed quickly and easily. Each side is hinged to swing out to the side and completely vertical. I will try to post pictures of this soon . I really like this feature.
On a properly aligned mill, you should not be throwing bands to require protection.
bedway
Especially if you dont try to back out of a cut! Dont ask me how i know this :-X
roghair
Hi Bruce29, I am interested in your gallery but I think it is not available anymore... Is there a way to put it online again? I am also making a (simple manual) sawmill and think I can learn a lot from your experience.
The carriage/sawhead is ready for the moment, but now I have to decide on the track, logstops, logholder, toeboards etc. How is your experience with your mill now that it is ready??
built a sawmill
roghair
built a sawmill
Herb Brooks
Exceptional work!  Hope mine comes out half that good.  Love the Farmall Red!
