Old single sided planer rebuild
Started by Quebecnewf, August 21, 2017, 05:25:44 AM
Quebecnewf
No there was no need to sharpen them . The bungee cord puts a little downward pressure on them and that is enough to make them dig in . Another good point you can release them very easily.
Quebecnewf
Quebecnewf
Decided to move planer to sawmill site yesterday . Here it is all strapped on sleigh and ready for trip to sawmill
This is the hill we have to get over. Made it almost to the top , got stuck, hooked up second snowmobile and made it to the top .
Heading down the back side . Sawmill in the distance
Tackling into the shed at the mill
All tucked into the new home . Ready to go to work come spring .
Quebecnewf
Southside
@Quebecnewf  Great job there for sure.  Those blades look like the ones on my chipper!!!  Do you have any photos of the triangle stacking you use?  I have never seen that and am wondering if we could use it down here.  Thanks
Quebecnewf
The triangle stacking is very simple . Lay three PCs of whatever your stacking in a triangle and just keep adding rows. You can , if you wish put 3 or 4 pcs in each leg of the triangle in order to get as much as possible in each stack before it gets too high .
The contractor who we made the stacks for in the pic ( 2x4x12)  had never seen this stacking system either. He was very impressed with the quality of the lumber and how dry and straight it was. Given the quality of the material being found at the big box stores now that is no suprise .
Quebecnewf
Don P
That's called crib stacking and was actually pretty common back in the day with SYP in the south. End racking up here with hardwoods was pretty common too. There was a demonstration rack my neighbor set up a Mabry Mill years ago, it may be gone by now.
YellowHammer
Are those yellow counter weights on the long yellow arms on the bottom of the planer?  Are they for the downpressure feed rollers?
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Southside
@Don P do know if that dried SYP faster that our modern sticker stacking?
Southside
Quote from: YellowHammer on February 25, 2018, 09:27:43 AM
Naa - that's just to give it some weight so it does not bounce around, you can see how flimsy that thing is.
Darrel
1992 LT40HD
Peter Drouin
Don P
Quote from: Southside logger on February 25, 2018, 01:21:07 PM
I don't know, maybe marginally more airflow but there's less support and a wider contact area at the ends. I think just like us they hated to make stickers . I've heard people say that end racking let the water drain out the bottom, ahhh right
Quebecnewf
We have the old planer set up at the mill now. We have been doing some spring sawing . Going to make the first planer run later today . Have about forty pcs. Of 2x4x12' that we are going to dress four sides.
This will be the first real trial of the old planer . Pic will be posted later tonight .
I have rebuilt the old engine that came with the planer . Carb needed rebuilding . Many thanks to good guy from The Smokstak Forum ( angry sailor ) for the rebuild. Started the second pull and runs smooth and strong .
Quebecnewf
Quebecnewf
Here is the old engine . It's a Montgomery /Onan . Made in Brazil of all places.
Around 10 hp I think
Quebecnewf
Quebecnewf
No pic today. Ran the planer a bit but having issues with the belt lashing that I used. Did manage to plane about 10 pcs. And that looked real nice.
Try again tomorrow with new lashing . Maybe pics tomorrow.
Quebecnewf
Quebecnewf
Flat belt planer running after 18 years - YouTube
A short video of planer . Ran 50 pcs of 2x4x12 through it . Once I get all the belting issues sorted it's going to be a great machine. Ran these 50 pcs . Very smooth finish . Planes at a good clip . I was just keeping 2 pcs at a time in the throat but I am sure if I was wanting to you could easily run 3 pcs at a time . Very little vibiration this is where the 1000 lbs of weight comes into play.
Was a great thrill to see it run again . When I think back to how it looked at the first I am more than pleased .
Quebecnewf
69bronco
Great job on the restoration!  Always nice to see old iron running again!
Quebecnewf
Very good chance that I will be getting another planer ( same name as the other ) to rebuild in the coming  weeks . Will post pics if I get the deal done .
Quebecnewf
Quebecnewf
Other planer has arrived and the rebuild has started. Same name as the first one but 20" and a round head .
Planer is in much better shape than the first one .
This big old electric motor came with it .3 hp /220V . Runs real smooth but weighs 100 lb .
More pics to follow
Quebecnewf
Don P
I'd bet that is an honest 3 work horses. If you ran it I'm guessing its single phase 240 volt.
The planer looks about identical, was the round head stock or swapped out later? A round head produces a better cut if that factors into keeping one or the other.
Quebecnewf
First tore it down
Then painting and cleaning
Then start rebuilding
Going to be an amazing machine I think .
QUEBECNEWF
Darrel
8) 8)  8)
8) 8) LOOKS VERY AMAZING  8) 8)
8)  8)  8)
1992 LT40HD
Quebecnewf
br>
Got the old electric motor all cleaned and painted . Ready to work again .
Quebecnewf
Papa1stuff
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Quebecnewf
dustintheblood
Quote from: Quebecnewf on September 04, 2018, 06:57:34 PM
Rebuild going ahead
Holy crap I can't believe I've missed this thread!!!
I have to give you a standing ovation for what I've seen even though I've only skimmed this thread (it's 2am and I've been working all night recommissioning my kiln).
I cannot wait to read it in detail tomorrow.
Congratulations and great work!
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
