Bar won't come out on my fabtek 4 roller head?
Started by lumbertick, December 29, 2015, 08:05:36 PM
lumbertick
Saw bar won't come out and the chain barley spins? Any suggestions I took out both valves on the block on top of pump and cleaned them.
bushmechanic
Sure sounds like an oil flow issue to me. Will it feed a stick without any problems? If so then I would figure that it's not machine related but either the valve for the saw or the electrics or the saw motor itself.
huskyxp
My harvester isn't Fabtek but will act like that when one of my high/low pressure (hydraulic) electric coil packs isn't workin (usually broken wire)
lumbertick
Thanks everyone we found the saw motor to be bad itself.. Got one coming boy they don't give those away
