A different kind of saw.
Started by Dave Shepard, March 07, 2009, 07:01:06 PM
Dave Shepard
Today was the official running of the diamond wire saw I have been helping a friend build. It arose from a pile of wire saw parts, and other industrial surplus. It was modified to cut larger blocks of marble, up to about 20 tons. I was told you don't want to mess with anything smaller than a mini-van. :D We've been working on the saw for about 4 1/2 years, it's great to see it finally run. 8)
This block was taken out of the quarry across the valley from me. It will be sawn into 24" square floor tiles.
isawlogs
Now thats a  SAW   8) 8) 8)
   Marcel
beav39
nice piece dave,your always building something,are you sawing much timber?
sawdust in the blood
woodbowl
I went to Marble Colorado years ago to see where the marble was mined that was used in building the monuments in Washington D.C.  The old timers said that a cable was used to cut it out of the mountain.  I didn't understand the process then, but I'm pretty sure that it is simular to this. Do you have a close up pic of the wire?
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
Dave Shepard
I don't have a close up, but I could get one at some point. When sawing blocks out of a mountain, you drill down from the  top of the bench to the depth of the block you desire, then you drill into the face to the bottom of the top hole. Then you feed the wire through to a machine that has only one drive wheel. Then you run the wire and it cuts the block out. There are several steps to it, but once the block is freed, an inflatable pad is slipped into the vertical cut, and is used to push the block over onto a pile of small quarry ruble to cushion it. The blocks can be 50 or more tons. Explosives are not used as they will create shot cracks that will ruin the stone. There are also giant chainsaw like tools mounted on crawlers that will saw the bottom of the block off. Lasers have been tried, but they only leave a paper thin cut, which you cannot get the pads into, and also will close up immediately. Cuts a couple inches wide will close up. As my friend says, the mountain is just reminding you who is really in charge. :D
beav39, I haven't been sawing this winter, but will be again soon. Going to cut some sycamore for Q sawing, and some big pines for plank flooring.
woodbowl
About the cable, I got the idea that it was just a plain ordinary cable and have no idea of it's diameter.  I can only imagine how they did that back in the day.
Dave Shepard
A diamond cable is about 3/16" in diameter. It has little brass "beads" on it that have diamond bort embedded in them. Basically just little chips of industrial diamond. As the brass wears away, it reveals more bort. The beads are about 3/8" diameter. There is a spring about an inch long in between each bead. Earlier methods of sawing stone was with a crosscut saw, with no teeth, and sand. As the saw wore down, it would become thin in the middle. Picture an 8' piece of 1/8"x 4" wide piece of sheet steel. On the steam gang saws, these saw blades would wear down to less than 2", then snap. Before the crosscut, was feathers and wedges. This is still the fastest way to break down large blocks into manageable, somewhat cube shaped pieces. As we work around the quarry, we find a lot of these broken blades, among other treasures. I found a hand forged stone set, it must have been laying there for a hundred years. We have also found many hooks and other signs of rigging.
Onthesauk
I've seen a special, (maybe on the Discovery Channel,) about cutting stone with a wire saw.  Quite a process.  They were taking out massive chunks of rock.
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
metalspinner
I kept looking for the saw in the pic but couldn't find it.  Then I "Zoomed" my vision out. :o
Does the rock move through the saw?  How is the power feed set up?  What kind of time does it take to cut that piece in the pic? ;D
TexasTimbers
Looks like to me the rock is on a frame which sits on two rails. Rock moves through the wire. Those bandwheels have to be massive.
That's very impressive Dave. A video of this would be very much appreciated.
That is neat.
Charlie and  I were taken to a Marble Quarry in North Georgia where Pink Marble was mined.   It was very unique and was used in the Capitol.   Blocks were drilled and broken from the mountain with wooden wedges that were soaked in water after their insertion.  Sometimes small charges were used. The blocks were treated very carefully to keep them from breaking.
Inside of the "shop" was a large wire saw that cut sheets from the blocks.  Some of these sheets were turned into gravestones and we watched as a rubber mat/stencil was applied and sandblasting created the pictures and words.
I'll never forgt that trip.
The wire saw they used was just plain wire.  Water was run onto the moving wire and the slurry that was created from the cutting helped the wire to cut.  In a matter of hours, huge blocks were sliced like bread.
fishpharmer
Just when I was starting to think my homemade mill had a wide cut ;) :D ;D
I had to look twice to see the mill too.
How big are those bandwheels?
What HP?
I hate to ask what a diamond blade costs.
Human ingenuity always amazes me.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
DR Buck
That's nothing.   I've cut rocks alnost that big with my Wood-Mizer.   :D :D :D :D :D :D :D :D
    I also found the saw after my 2nd look.   I couldn't figure out why you took a picture of the building and told us there was a saw (in there).   ;D
Ironwood
Nice, I have been thinking about working in rock more and more. While that is too big for me, I would be interested in wire cost as well. Most of my cutting would be sandstone salvaged from barns, cutting to use in furniture.
   Ironwood
Dave Shepard
Here is a different angle. The wheels move up and down on the two columns you see on the left. Between the two columns is a 2" acme screw. This is on a variable speed drive to control the feed rate. The block is stationary during the cut, but can be rotated on the car. If you wanted to make a cube, you would make cuts every 90 degrees. The car also slides in and out. At present, the car is not motorized, but the two cars inside for the radial saw are.
Diamond wire is anywhere from $85 to $125 per meter. This saw probably uses 25 meters. The saw surprisingly only uses a 10HP DC motor on a variable speed drive. It is not as fast as the radial saw, but will handle much larger blocks, whereas the radial is limited to about a 25" depth of cut. Previously to work up a big block required sawing many parallel cuts across the top of the block to a uniform depth, then snapping them off. Just like you would with a timber and a circular saw making a lap joint. The radial saw has been modified to do this automatically, but still requires a significant amount of time. Now, you can have a block on the wire saw getting sized, while you are making parts on the radial saw. Each of these saws has a pair of cabinets full of PLCs, VFDs and miles of wires to connect everything.
Warbird
Wow!  That is impressive.  I bet you guys had to eat good while building that.  Specifically, I bet it took a lot of grits.  ;D
Dave Shepard
No grits were harmed during the construction of this machine. 8) :D
rebocardo
Impressive and cool - thank you for the pictures  :)
isawlogs
  I saw a program today where they where cutting soap stone with a wire and they had a close up of it (wire) .It is exactly how you described it  :P :) They had drill a vertical hole and a horizontal hole and fished the wire through and crimped it together, then fed it through the band wheel and proceeded to cut a big block out of the mountain .
   All the time I watched I thought of this thread .....  ;D 8) 8)
   Marcel
ErikC
  You never know what we are going to know about here on the Forestry Forum. :) Very cool Dave, Thanks 8)
woodbowl
Quote from: isawlogs on March 08, 2009, 09:10:38 PM
Marcell, what happens when they get to the crimp? Did they pull the crimp through the cut or reverse the direction each time?
Dave Shepard
The crimp goes through the cut. It is about an inch and a quarter long. The radius of the cut is never small enough to kink the wire of the crimp.
isawlogs
The crimp just pulled through like Dave said , it sure was cutting at a good speed too  8)
   Marcel
tyb525
Hate to bring this topic up again, but what are the chances of using a diamond wire saw on a WM with the belts removed? Or use an old band with the teeth ground off and water slurry to cut till the blade wears out?
isawlogs
 Dont know what would happen , no need to use a Woodmizer for that test any ol mill will do .  ;)  Give it a shot and bring this back up with a report  :P
   Marcel
