Accuset2 Setworks question?
Started by 038magnum, October 20, 2012, 12:43:31 PM
038magnum
I have been playing some with my new mill cutting 1 1/8" boards. I had Accuset programed with the correct kerf for the blade that I am using. The mill started out cutting 1 1/8" thick. next day it was 1 3/16". Now it is cutting 1 1/4". What might be causing this?
Bibbyman
Just occasionally?  Or every board?
I'd say a conversation with Sparks at Wood-Mizer would get you back on track quicker.
I've never had that happen.
Sawing since '94
rmack
2 cents from the uneducated... sounds like a reference point moving.
Does your bottom of low tooth to deck measurement still jive?
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
terrifictimbersllc
.....and have you ruled out the cant moving from stress, this throws board thicknesses all over the place (usually ends thinner and middles thicker).
038magnum
Thanks for the advice. I will play more with it tomorrow.
