timberjack 450
Started by loghog, August 21, 2014, 09:12:16 PM
loghog
We are running 30-32 tires on this machine and I was wondering if the big tires take more hp then smaller tires would?
tj240
yes need more power to turn them unless they are the size in came from the factory with
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
loghog
I don't know what factory size was I have seen em with with smaller ones on . we are thinking about change to 26-24 tires if it would gain anything
treeslayer2003
on yer 450? 6bt should have plenty of power. i have a 666 clark i swapped 28s on cuz the 4-53 didn't like 34s.
where you at in the world?
loghog
This one got the Detroit in it wish it had a cummins in it
I'm located close Harrisburg PA
Ken
I had the same machine although it had 23.1 x 26 tires.  I took them off and put on 18.4 x 34 and made it a faster and quite a bit narrower although it did make it a bit more tippy.
loghog
Sounds like a very tippy machine Ken but I could use your old rims
ga jones
The pump settings would vary for tire size frame lenght grapple or cable on a cummins. On a detroit it would be injector size. Not enough power bump up one injector size. Or turn the governor a little.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
ga jones
6bt cummins varyied from 120 to 200 horse depending on pump style,application. 453 detroit varyied a little less. Turbo detroits are a little higher.
loghog
This 450 got a turbo on it I could go one size bigger on injector mechanic thinks we are around 170 hp we just rebuilt engine.         Today I could not keep the tranny cool it was running 200-220 .
snowstorm
if its a clark trans 200 is just rite. my valmet book says 200 to 250
loghog
Thanks for the info guys
ehp
I ran 23.1 by 26 on that same machine and it worked very well in my ground
